Ilogic Part Array
Ilogic Part Array
jam_bhatti
Ilogic Part Array
jam_bhatti
I am working on Vessel Shell assembly with variable shell height and wall thickness using ilogic, and i am trying this using array tool. can any one help me how i define perameter in array using ilogic to allow me different height and wall thickness in array.
Component key names are
Shell Diameter = ID
Shell Height = HT
Shell wall Thickness = THK
Array tool using column number of shell n=4 or 5 or 6 etc.
Does anyone know to do this with ilogic?
mdavis22569
There are a few on this board.   However you'll find far more help on the Inventor customization forum
http://forums.autodesk.com/t5/inventor-customization/bd-p/120
and yes it can be done ..with some true and false and if this is that ..it equals. I'm not great at Ilogic so I won't pretend to try and give you an answer.
Mike Davis
Curtis_Waguespack
Hi jam_bhatti,
In addition to the previous reply, attached is a quick example file that might help.
I hope this helps.
Curtis
Example code:
'define the array list
IDlist = new integer(){3,4,5,6}
'or you could use this:
'IDlist  = new string(){3.5,4.5,5.5,6.5}
'get the user input
ID = InputListBox("Select an Inside Diameter.",IDlist, ID, "iLogic", "ID Values")
'update all
iLogicVb.UpdateWhenDone = True
'zoom all
ThisApplication.ActiveView.Fit
mdavis22569
@Curtis_Waguespack  is one of the ones on there that does know Ilogic that I was referring to
Mike Davis
jam_bhatti
@ Curtis_Waguespack/mdavis22569
i appreciate your quick feedback and please accept my apology to i cannot convey correctly the problem what i want
find the attached image to express that problem in light of my first post.
The diameter remain same, only height and thickness of shall value need to be change in component pattern stages.
i hope it can be possible through ilogic/vb.
