Ilogic If part exists then use different mate offset value
Im trying to figure out the code in a rule for searching for a part that contains the name "ZAP" and if the part is in there the following mate of the next inserted part offset value is to be increased by .079. If the part cannot be found then forgo the .079 increase.
Any help please?
I am able to get this to detect the part true or false
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oComps As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
Dim PartExists As Boolean = False
For Each oComp As ComponentOccurrence In oComps
	If oComp.Name.Contains("ZAP") Then
		PartExists = True
		Exit For
Next
But i cant get if partexists = true then
(constrain with this dimension)
else if part exisit = false then
(constrain with other dimension)
johnsonshiue
Hi! "Exit For" will abort the For Loop. Is it what you want?
Many thanks!
Software Test Engineer
