ilogic form in iam - change parameters in ipt
適用対象外
930件の閲覧回数
10件の返信
メッセージ1/11
適用対象外
Hi guys!
Currently having a problem with a parametric assembly that I'm trying to do.
I have created two USER PARAMETER in an iam and I want them to drive the parts.
This I can do using this code:
SyntaxEditor Code Snippet
Parameter("TRANSFERT GAUCHE-DROITE - EMA60XXWLA.ipt", "LARGEUR")=LARGEUR_MAITRE
Parameter("TRANSFERT DROITE-GAUCHE - EMA60XXWLA.ipt", "LARGEUR")=LARGEUR_MAITRE
Parameter("COTE 2 - EMA60XXWLA.ipt", "LARGEUR")=LARGEUR_MAITRE
Parameter("COTE 1 - EMA60XXWLA.ipt", "LARGEUR")=LARGEUR_MAITRE
Parameter("BOUT PLEIN - EMAXX72WLA.ipt", "LONGUEUR")=LONGUEUR_MAITRE
Parameter("BOUT OUVERT - EMAXX72WLA - REV A.ipt", "LONGUEUR")=LONGUEUR_MAITRE
 But the problem is that the part in the assembly are also used elsewhere so I need them to be Ipart.
I tried using a custom parameter in the iPart table but it seems like it cant be driven by a parameter.
I need inventor to create a new member for the iPart. This way I'd just have to change my two parameter to create a couple of iPart.
Is it possible?
0 件のいいね
931件の閲覧回数
10件の返信
返信 (10)
メッセージ2/11
johnsonshiue
Hi! It can be either a syntax error, or context inconsistency, or it just cannot be done. WIthout the dataset, it is hard to tell where the problem is. Could you provide an example?
Many thanks!
Software Test Engineer
0 件のいいね
メッセージ3/11
Owner2229
Hey, this should get you started:
Sub Main()
     Dim oDoc As Document = ThisApplication.ActiveDocument
     If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
     Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
     Dim sLar As Parameter = oCD.Parameters.UserParameters.Item("LARGEUR_MAITRE")
     Dim sLon As Parameter = oCD.Parameters.UserParameters.Item("LONGUEUR_MAITRE")
     For Each aDoc As Document In oDoc.AllReferencedDocuments
          Dim sName As String = aDoc.DisplayName
          Select Case sName
          Case "TRANSFERT GAUCHE-DROITE - EMA60XXWLA.ipt":  DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "TRANSFERT DROITE-GAUCHE - EMA60XXWLA.ipt":  DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "COTE 2 - EMA60XXWLA.ipt":                   DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "COTE 1 - EMA60XXWLA.ipt":                   DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "BOUT PLEIN - EMAXX72WLA.ipt":               DrivePart(aDoc, "LONGUEUR", sLon.Value, sLon.Units)
          Case "BOUT OUVERT - EMAXX72WLA - REV A.ipt":      DrivePart(aDoc, "LONGUEUR", sLon.Value, sLon.Units)
          End Select
     Next
End Sub
Private Sub DrivePart(oDoc As Document, sParaName As String, oValue As Object, sUnits As String)
     Dim oFactory As iPartFactory
     If oCD.iPartFactory Is Nothing Then
          oFactory = oCD.CreateFactory
     Else
          oFactory = oCD.iPartFactory
     End If
     Dim bExist As Boolean = False
     Dim iCL As Integer = 0
     For Each oCl As iPartTableColumn In oFactory.TableColumns
          If oCl.Heading = sParaName Then
               bExist = True
               iCL = oCl.Index
               Exit For
          End If
     Next
     Dim oUM As UnitsOfMeasure = oDoc.UnitsOfMeasure
     Dim oParameter As Parameter
     Try
          oParameter = oCD.Parameters.UserParameters.Item(sParaName)
     Catch
          oParameter = oCD.Parameters.UserParameters.AddByValue(sParaName, oValue, sUnits)
     End Try
     Dim oWorkSheet As Object = oFactory.ExcelWorkSheet
     Dim oCells As Object = oWorkSheet.Cells
     Dim iColumns As Integer = oFactory.TableColumns.Count + 1
     Dim iRows As Integer = oFactory.TableRows.Count + 1
     If Not bExist Then
          oCells.Item(1, iColumns) = sParaName
          oCells.Item(2, iColumns) = oUM.GetStringFromValue(oParameter.Value, oParameter.Units)
          oCells.Item(iRows, iColumns) = oUM.GetStringFromValue(oValue, oParameter.Units)
     Else
          Dim bFound As Boolean = False
          For i = 1 To iRows
               If oCells.Item(i, iCl) = oValue Then
                    bFound = True
                    Exit For
               End If
          Next
          If Not bFound Then
          End If
     End If
     Dim oWB As Object = oWorkSheet.Parent
     oWB.Save()
     oWB.Close()
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
メッセージ4/11
適用対象外
It does look like it would do what I want it to do.
Trying to make it work. I had to remove the .ipt at the end of the part name, if I keep the .ipt at the end it does nothing. Now i'm getting an error.
'Public Shared Operator =(left As Double, right As Double) As Boolean':
I can't figure out what it means. Seems to be linked to the bExist and bFound as they are the only Boolean operator in this. Ever encountered this error?
Sub Main()
     'verify that oDoc is an assembly
     'set variable for main parameter
     'run the private sub for each part
          Select Case sName
          Case "TRANSFERT GAUCHE-DROITE - EMA60XXWLA":  DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "TRANSFERT DROITE-GAUCHE - EMA60XXWLA":  DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "COTE 2 - EMA60XXWLA":                   DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "COTE 1 - EMA60XXWLA":                   DrivePart(aDoc, "LARGEUR", sLar.Value, sLar.Units)
          Case "BOUT PLEIN - EMAXX72WLA":               DrivePart(aDoc, "LONGUEUR", sLon.Value, sLon.Units)
          Case "BOUT OUVERT - EMAXX72WLA - REV A":      DrivePart(aDoc, "LONGUEUR", sLon.Value, sLon.Units)
          End Select
     Next
End Sub
     'verify if the part is an iPart
     Else
     End If
     'verify if a column already exists for the parameter
               bExist = True
               iCL = oCl.Index
               Exit For
          End If
     Next
     'adds the value to the parameter
     Try
     Catch
     End Try
     'creates new column for the parameter if it doesn't exist
     If Not bExist Then
     'validate if the value has changed
     Else
          For i = 1 To iRows
                    bFound = True
                    Exit For
               End If
          Next
     'if not the same adds the value
          If Not bFound Then
          End If
     End If
     oWB.Save()
     oWB.Close()
End Sub
0 件のいいね
メッセージ5/11
Owner2229
Hmm, that's strange. You can try write in something like MsgBox("here") and move it by every few rows to see "how far the code gets before it crashes".
Anyway, you've got the descriptions mostly right, except for:
'adds the value to the parameter >> 'adds the parameter if it doesn't exist
'validate if the value has changed >> 'checks if the iPart column contains the value
Mike
メッセージ6/11
適用対象外
Thanks for the description.
Using the message text box I found out that the error is somewhere in there.
     If Not bExist Then
     Else
          For i = 1 To iRows
               If oCells.Item(i, iCL) = oValue Then
                    bFound = True
                    Exit For
               End If
          Next
          If Not bFound Then
          End If
     End If
0 件のいいね
メッセージ7/11
適用対象外
     If Not bExist Then
I dont get the difference between the two last rows.
0 件のいいね
メッセージ8/11
Owner2229
The second row ads the current (original) value from the part's parameter and the last row adds the value required by assembly.
Also, you can try this:
     If Not bExist Then
          oCells.Item(1, iColumns).Value = sParaName
          oCells.Item(2, iColumns).Value = oUM.GetStringFromValue(oParameter.Value, oParameter.Units)
          oCells.Item(iRows, iColumns).Value = oUM.GetStringFromValue(oValue, oParameter.Units)
     Else
          For i = 1 To iRows
               If oCells.Item(i, iCL).Value = Cstr(oValue) Then
                    bFound = True
                    Exit For
               End If
          Next
          If Not bFound Then
          End If
     End If
I guess this line was causing the error:
Mike
メッセージ9/11
適用対象外
The problem is in this line
I changed the type of oValue from sting to double but it still doesn't work
Edit: you already replied to this one hehe Thanks
0 件のいいね
メッセージ10/11
適用対象外
Got it to work! Thanks a lot for your help!
Sub Main()
    Value_largeur = oUM.GetStringFromValue(sLar.Value, sLar.Units)
    Value_longueur = oUM.GetStringFromValue(sLon.Value, sLon.Units)
        Select Case sName
        Case "TRANSFERT GAUCHE-DROITE - EMA60XXWLA":  DrivePart(aDoc, "LARGEUR_USER", sLar.Value, sLar.Units)
        iPart.ChangeRow("GAUCHE-DROITE", Value_largeur)
        Case "TRANSFERT DROITE-GAUCHE - EMA60XXWLA":  DrivePart(aDoc, "LARGEUR_USER", sLar.Value, sLar.Units)
        iPart.ChangeRow("DROITE-GAUCHE", Value_largeur)
        Case "COTE 1 - EMA60XXWLA":                   DrivePart(aDoc, "LARGEUR_USER", sLar.Value, sLar.Units)
        iPart.ChangeRow("COTE 1", Value_largeur)
        Case "COTE 2 - EMA60XXWLA":                   DrivePart(aDoc, "LARGEUR_USER", sLar.Value, sLar.Units)
        iPart.ChangeRow("COTE 2", Value_largeur)
        Case "BOUT PLEIN - EMAXX72WLA":               DrivePart(aDoc, "LONGUEUR_USER", sLon.Value, sLon.Units)
        iPart.ChangeRow("BOUT PLEIN", Value_longueur)
        Case "BOUT OUVERT - EMAXX72WLA - REV A":      DrivePart(aDoc, "LONGUEUR_USER", sLon.Value, sLon.Units)
        iPart.ChangeRow("BOUT OUVERT", Value_longueur)
        End Select
    Next
End Sub
Private Sub DrivePart(oDoc As Document, sParaName As String, oValue As Double, sUnits As String)
    Else
    End If
    For Each oCL As iPartTableColumn In oFactory.TableColumns
        If oCL.Heading = sParaName Then
            bExist = True
            iCL = oCL.Index
            Exit For
        End If
    Next
    Try
    Catch
    End Try
    Dim iRows As Integer = oFactory.TableRows.Count + 2
    Dim sValue As String = oUM.GetStringFromValue(oValue, oParameter.Units)
    If Not bExist Then
        MessageBox.Show("Le param�tre n'a pas �t� cr�� dans la pi�ce", "iLogic")
'        oCells.Item(1, iColumns).Value = sParaName'        oCells.Item(2, iColumns).Value = oUM.GetStringFromValue(oParameter.Value, oParameter.Units)'        oCells.Item(iRows, iColumns).Value = oUM.GetStringFromValue(oValue, oParameter.Units)
    Else
        For i = 1 To iRows
            If oCells.Item(i, iCL).Value = sValue Then
                    bFound = True
                    Exit For
            End If
        Next
    'if not found, adds the value
        If Not bFound Then
        oCells.Item(iRows, 1).Value = sValue
            For i = 2 To iCL - 1
                tmp = oCells.Item(iRows - 1, i).Value
                oCells.Item(iRows, i).Value = tmp
            Next
            oCells.Item(iRows, iCL).Value = sValue
        End If
    End If
    oWB.Save()
    oWB.Close()
End Sub
0 件のいいね
メッセージ11/11
Owner2229
You're welcomed スマイリー ハッピー
Mike
0 件のいいね
