第 1 条消息(共 3 条)
iLogic form edit property with formula
So I have my content center parts set up to populate the description property with a formula, for an angle it is set to =L <G_H> X <G_W> X <G_T> X <G_L>. The issue I'm running into is when the parts are generated as custom parts I also have an iLogic form that people use to update all the relevant properties of the file and the form won't allow a change to the description property, I'm assuming because it is a formula rather than just a string. Is there a way to let the form be able to override the formula with typed in text?
Andrew In’t Veld
Designer / CAD Administrator
