Hi. I have written an iLogic rule that is supposed to first update the model and mass properties. It will then define three parameters (Wid, Len and kFac). Subsequently it will use Wid and Len to write a string and define kFac as the kfactor only if sheet metal is active. However when I run this script, it gives the following error (only in Swedish not in English) "Det går inte att hitta en matchande överlagring eftersom ingen tillgänglig parametro accepterar det här antalet argument." (It is not possible to find a matching overlay because no available parametro accepts this number of arguments.). What is wrong in the code?
Sub Main() Dim PartDoc As PartDocument = ThisDoc.Document Dim userParams As UserParameters = PartDoc.ComponentDefinition.Parameters.UserParameters 'Mass properties ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute myMass = iProperties.Mass iLogicVb.UpdateWhenDone = True parametro = ThisApplication.ActiveDocument.ComponentDefinition.Parameters("Wid") Dim newParamW As UserParameter = userParams.AddByExpression("Wid", 0, "mm") parametro = ThisApplication.ActiveDocument.ComponentDefinition.Parameters("Len") Dim newParamL As UserParameter = userParams.AddByExpression("Len", 0, "mm") parametro = ThisApplication.ActiveDocument.ComponentDefinition.Parameters("kFac") Dim newParamK As UserParameter = userParams.AddByExpression("kFac", 0, "mm") newParamK.ExposedAsProperty = True Dim cFormat As CustomPropertyFormat = newParamK.CustomPropertyFormat cFormat.PropertyType = CustomPropertyTypeEnum.kTextPropertyType cFormat.Precision = CustomPropertyPrecisionEnum.kThirtySecondsFractionalLengthPrecision cFormat.ShowTrailingZeros = True cFormat.ShowUnitsString = False End Sub 'Material dimension Function parametro(Wid, Len) If SheetMetal.FlatExtentsArea>0 Then Wid = Ceil(SheetMetal.FlatExtentsWidth) Len = Ceil(SheetMetal.FlatExtentsLength) If Wid = Len Then iProperties.Value("Custom", "Material dimension") = "□" & Wid & ", t = " & Thickness Else iProperties.Value("Custom", "Material dimension") = Wid & " x " & Len & ", t = " & Thickness End If End If End Function 'K-Factor Function parametro(kfac) If SheetMetal.FlatExtentsArea>0 Then kFac = SheetMetal.ActiveKFactor End If End Function
Thanks in advance
Solved by Sergio.D.Suárez. Go to Solution.
The first error visible at first glance, if kFac represents the factor k, keep in mind that its unit is "ul" (actually it means without units of measure because it is a constant).
Try to modify this and then tell us what error is triggered so we can help you, regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
The fault lies in line 8
line 10
and line 12
Hi, accommodate what I think you are trying to do.
I recommend that you work with subroutines, it's what works for me, I can cut and paste blocks that work because I can test them separately, if you use a function, use it only when you want to return a value to the submain for example.
First update the mass as you adjusted, then delete the existing variables (just in case they are wrong)
then it is updating parameters.
If you have a previous flattening eliminate it to avoid problems
Sub Main() 'On Error Resume Next Dim PartDoc As PartDocument = ThisDoc.Document Dim userParams As UserParameters = PartDoc.ComponentDefinition.Parameters.UserParameters 'Mass properties ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute2(True) myMass = iProperties.Mass iLogicVb.UpdateWhenDone = True Delete_Variables Check_Wid Check_Len Check_kFac parametro1 parametro2 Parameter.UpdateAfterChange = True iLogicVb.UpdateWhenDone = True End Sub Sub Delete_Variables() On Error Resume Next Dim p1 As Parameter Dim p2 As Parameter Dim p3 As Parameter p1 = ThisDoc.Document.ComponentDefinition.Parameters.Item("Wid") p2 = ThisDoc.Document.ComponentDefinition.Parameters.Item("Len") p3 = ThisDoc.Document.ComponentDefinition.Parameters.Item("kFac") End Sub Sub Check_Wid Try Dim a1 As Parameter a1 = ThisDoc.Document.ComponentDefinition.Parameters.Item("Wid") Catch Dim a1 As Parameters a1 = ThisDoc.Document.ComponentDefinition.Parameters a1.UserParameters.AddByExpression("Wid","20","mm") oA1 = Parameter.Param("Wid") oA1.ExposedAsProperty = True oFA1=oA1.CustomPropertyFormat oFA1.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFA1.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision oFA1.ShowUnitsString=False oFA1.ShowTrailingZeros = False oFA1.ShowLeadingZeros = False End Try End Sub Sub Check_Len Try Dim a1 As Parameter a1 = ThisDoc.Document.ComponentDefinition.Parameters.Item("Len") Catch Dim a1 As Parameters a1 = ThisDoc.Document.ComponentDefinition.Parameters a1.UserParameters.AddByExpression("Len","30","mm") oA1 = Parameter.Param("Len") oA1.ExposedAsProperty = True oFA1=oA1.CustomPropertyFormat oFA1.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFA1.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision oFA1.ShowUnitsString=False oFA1.ShowTrailingZeros = False oFA1.ShowLeadingZeros = False End Try End Sub Sub Check_kFac Try Dim a1 As Parameter a1 = ThisDoc.Document.ComponentDefinition.Parameters.Item("kFac") Catch Dim a1 As Parameters a1 = ThisDoc.Document.ComponentDefinition.Parameters a1.UserParameters.AddByExpression("kFac","0.33","ul") oA1 = Parameter.Param("kFac") oA1.ExposedAsProperty = True oFA1=oA1.CustomPropertyFormat oFA1.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType oFA1.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision oFA1.ShowUnitsString=False oFA1.ShowTrailingZeros = False oFA1.ShowLeadingZeros = False End Try End Sub 'Material dimension Sub parametro1 Dim oWid As Parameter oWid = ThisDoc.Document.ComponentDefinition.Parameters.Item("Wid") Dim oLen As Parameter oLen = ThisDoc.Document.ComponentDefinition.Parameters.Item("Len") If SheetMetal.FlatExtentsArea>0 Then oWid.Value = Ceil(SheetMetal.FlatExtentsWidth) oLen.Value = Ceil(SheetMetal.FlatExtentsLength) If oWid.Value = oLen.Value Then iProperties.Value("Custom", "Material dimension") = "□" & oWid.Value & ", t = " & Thickness Else iProperties.Value("Custom", "Material dimension") = oWid.Value & " x " & oLen.Value & ", t = " & Thickness End If End If End Sub 'K-Factor Sub parametro2 Dim okFac As Parameter okFac = ThisDoc.Document.ComponentDefinition.Parameters.Item("kFac") If SheetMetal.FlatExtentsArea>0 Then okFac.Value = SheetMetal.ActiveKFactor End If End Sub
I hope you find it useful, greetings
Mechanical Designer
