Inventor Forum
iLogic Error Check
3 REPLIES 3
1653 Views, 3 Replies
iLogic Error Check
Hello all!
I put together a configurator with iLogic and I wanted it to check for errors before allowing save. I was using the following code to do this:
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 5886 StartFragment: 314 EndFragment: 5854 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
For Each oFeature As PartFeature In ThisDoc.Document.ComponentDefinition.Features
If oFeature.HealthStatus <> HealthStatusEnum.kUpToDateHealth Then
Question = MessageBox.Show("Errors were found in crossmember, suppress errors?", "Notice!",MessageBoxButtons.YesNo,MessageBoxIcon.Exclamation)
    If Question = vbYes Then
        oFeature.Suppressed = True
    Else If Question = vbNo Then
        MessageBox.Show("Please review crossmember", "Notice!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation)
    End If
End If
Next
 This code works great, except it considers suppressed features as errors. Is there another way to check for errors, or something to add to this code so that it will accept suppressed features?
Thanks!
3 REPLIES 3
Curtis_Waguespack
Hi DanielPenner,
You could check for those with kSuppressedHealth first and skip those.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Hey Curtis, so I put kSuppressedHealth in my code and I works. The onle problem is it runs my "SaveAs" Sub for each feature. I'm pretty sure I'm missing something I just cant seem to figure out what.
Sub Main
InventorVb.DocumentUpdate()
If oFeature.HealthStatus = HealthStatusEnum.kSuppressedHealth  Or oFeature.HealthStatus = HealthStatusEnum.kUpToDateHealth Then
    SaveAs
Else Question = MessageBox.Show("Errors were found in crossmember, suppress errors before saving?", "Notice!",MessageBoxButtons.YesNo,MessageBoxIcon.Exclamation)
        SaveAs
    End If
End If
Next
End Sub
Curtis_Waguespack
Hi DanielPenner,
Give this version a try.
I hope this helps.
Curtis
Sub Main
Dim bHealthy As Boolean
bHealthy = True 'use true as defaut
'precheck
	If oFeature.HealthStatus = HealthStatusEnum.kSuppressedHealth Then
		'do nothing
	Else If oFeature.HealthStatus <> HealthStatusEnum.kUpToDateHealth Then
		bHealthy = False
		Exit For 'found unhealthy so exit
	End If
Next
'work with unhealthy features
If bHealthy = False Then
	Question = MessageBox.Show("Errors were found in crossmember, suppress errors before saving?", _
				'do nothing
			End If
		Next
		'do save as here
	End If
Else 'bHealthy is True
	'do save as here
End If
End Sub
Technology Administrators
