@leandropinhao wrote:
This is a sheet metal part and I have 2 parameters that change: height and width, that are controlled by an excel table.
I´m generating several flat patterns with height and width.
In the case of the holes I want to distribute this holes with more or less 250mm according the width value I put.
So you are doing this sheet metal part as an ipart?
How can you have the same part number being physically different?
But back to your question
Is there no "set spacing" between holes? or do you just want to change the spacing of the holes (and not add more or less holes) as the part grows/shrinks?
If you just need to change the spacing then you need to make the spacing dimension be the result of a formula..
Where.. that 250mm dimension is divided by the number of holes you want..
So if 250 = d2
Then set the spacing between the holes to be d2/7
