I have a form used to select from pre-defined settings (case statements in the rule) and custom entry.
I have a drop down that provides the selections from the pre-defined stuff or custom with fields that show the results.
If custom is selected the user is prompted to enter data in popup dialog boxes which all works fine but I would rather select custom and enter the data in the fields on the form than in the popup. can that be done?
See the png files
I want to just enter the data in without the popup box
Solved by pcrawley. Go to Solution.
if 2012-2013-2014 go to manage, ilogic browser, forms, right click in the space, create new.
on the left you will see all your possible parameters, drag to the middle, and these forms can be edited in place. 😉
You need to allow your multi-value parameters to accept custom values (which I suspect you've already done).
But on the form, you have to do it again. See below:
