Inventor Forum
iLogic - Creating STL with options
7 REPLIES 7
Message 1 of 8
2288 Views, 7 Replies
I created a iLogic routine to generate a STL file if the iProperty "Printed Part" is set to YES.
I am getting an error when Ln33 oTranslator.SaveCopyAs(oDocument, oContext, oOptions, oData) is executed.
Any help would be appriciated
If iProperties.Value("Custom", "Printed Part") = False Then 'False = "NO"
	Return
Else
	MsgBox ("Selected to output STL for printing" & vbCrLf & "Disable by setting the custom iProperty:Printed Part to NO")
End If
'Create _OUTPUTS directory
oPath = ThisDoc.Path
oFolder = oPath & "\" & iProperties.Value("Custom", "Output Directory")
'Check for the custom iProperty directory and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
' Get the STL translator Add-In.
Dim oTranslator As TranslatorAddIn
oTranslator = ThisApplication.ApplicationAddIns.ItemById ("{533E9A98-FC3B-11D4-8E7E-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Configure options and write out
If oTranslator.HasSaveCopyAsOptions (ThisApplication.ActiveDocument, oContext, oOptions) Then
	oOptions.Value("ExportUnits") = 1	'Inch	'Based off of index in combo box in STL Export Dialog
	oOptions.Value("Resolution") = 1	'High	'Based off of index of radio buttons in STL Export Dialog
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    Dim oFileName As String
	oFileName = ThisDoc.PathAndFileName(False)
	oData.FileName =  oFolder & "\" & oFileName & " Rev " & oRevNum  & ".stl" '
	'Write out file
Else
	MsgBox("!!!ERROR: STL File was not created!!!")
End If
Tags (2)
7 REPLIES 7
Message 2 of 8
I did find one code error, but did not fix my issue
Ln30 should be:
oFileName = ThisDoc.FileName(False)
Message 3 of 8
mrattray
You'll likely get a better response to programming questions on the Inventor Customization forum. This is where all of the developer types hang around.
Mike (not Matt) Rattray
Message 4 of 8
Old post, but did you found out waht your error was+
im interested to use this code also.
Best regards
Lennart
Message 5 of 8
t_hascj
Hi Lennart,
oDocument is uninitialized.
Jaroslav
Message 6 of 8
in reply to: t_hascj
Sorry, but i dont understand?
Is there a code that works.
Lennart
Message 7 of 8
t_hascj
You ask about solution for code in the first post. You need to initialized the oDocument.
oDocument = ThisApplication.ActiveDocument ' add this code
Here is another code https://forums.autodesk.com/t5/inventor-forum/ilogic-save-as-stl-in-mm-with-high-quality/m-p/7287161...
Thanks.
Message 8 of 8
Aha ok i got it.
Thanks man.
