iLogic code to Save File
Hey All,
I'm trying to save a file as "PartNumber-SequenceNumber" with iLogic code. For example, 12345678-0001.ipt is how a file would be saved.
So far, what I've got is this:
Dim PartNumber As String
Dim SequenceNumber As String
PartNumber = iProperties.Value("Project", "Part Number")
SequenceNumber = iProperties.Value("Custom", "Sequence Number")
ThisDoc.Document.SaveAs("PartNumber""-""SequenceNumber", False)
How can I do this better? Right now, I'm getting the following error code:
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Thanks!
  -Luke
Curtis_Waguespack
Hi nealon.luke,
 Something like this should work, although I didn't test it.
I hope this helps.
Curtis
ThisDoc.Document.SaveAs(PartNumber & "-" & SequenceNumber, False)
Still getting this error even with that fix...
Curtis_Waguespack
Hi nealon.luke,
We need a path and file extension too. Also, I think you'll get an error if the file already exists, so you'd want to check for that as well.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
oPath = "C:\TEMP\"
ThisDoc.Document.SaveAs(oPath & PartNumber & "-" & SequenceNumber & ".ipt", False)
Great, thanks Curtis
mcgyvr
Autodesk should update the code snippit then.. The snippit just says
ThisDoc.Document.SaveAs(NewFileNameAndExtension , True)
Should be this
ThisDoc.Document.SaveAs(PathAndNewFileNameAndExtension , True)
Curtis_Waguespack
Hi mcgyvr,
You're not wrong.
There are several areas in the iLogic tools and documentation that need:
  • ommisions added
  • incorrect information corrected
  • unclear or misleading information revised
  • working examples included
Overall some attention is needed to bridge the communication gap between the Autodesk iLogic developers who create and document the iLogic tools and the iLogic users, particularly new iLogic users.
In the past it seemed to me that much of the documentation, certification material, etc. was handed from software engineers who had never used the tools in a real world situation, to technical writers who had never used the tools in a real world situation. Resulting in vague and ambiguous documentation. The iLogic documentation has that feel about it.
To be fair though, I think iLogic has been used above and beyond what the Autodesk iLogic developers had in mind originally, as Inventor users have bent it to our will. In any case, it needs and deserves a bit of attention at this point, IMHO.
I hope this helps.
Curtis
