Inventor Forum
iLogic Code for feature detection
8 REPLIES 8
Message 1 of 9
2368 Views, 8 Replies
I am trying to get my ilogic code to detect if a hole feature is in the .ipt file AND active (not suppressed). Once the code decides yes or no it will populate a custom property which will end up on a BOM. Here is the code that I am currently working with:
SyntaxEditor Code Snippet
Dim oFeature As PartFeature
Dim oFeatures As PartFeatures
oFeatures = ThisDoc.Document.ComponentDefinition.Features
i = 0
For Each oFeature In oFeatures
	If oFeature.Name.Contains("Hole") = True
		While oFeature.Name.Contains("Suppressed") = False
		End While
	i = i+1
	End If
Next
If i > 0
	iProperties.Value("Custom", "Beamline") = "YES"
Else
	iProperties.Value("Custom", "Beamline") = "NO"
End If
Everything is working as expected except for the part that checks if the feature is active...
End While
This section causes Inventor to immediately freeze. I am guessing this is the wrong way to go about it... but it was my best shot. Can anyone give me a suggestion on how to detect if a feature (without a known name) both exists and is active?
8 REPLIES 8
Message 2 of 9
mcgyvr
To start..This just means while there is no name containing suppressed.. Do that..
and thats an endless loop if nothing contains suppressed....
The while is being met so its attempting to do "something while"...and inventor sits there waiting for the while to be true so it can exit..
		End While
and to answer your question..
If oFeature.Suppressed = True
Message 3 of 9
in reply to: mcgyvr
There is what I am looking at now.
There is an error with my And statement ( not sure why).
		And oFeature.Suppressed = False
		i = i+1
	End If
I also tried without the "And". It just suppresses the hole feature.
		i = i+1
	End If
 I have been staring at this for a long time, I am sure the answer is obvious, I'm just not getting it.
What am I missing here?
Message 4 of 9
mcgyvr
@Anonymous Sorry.. Here
i = 0
	'check if its a hole
	If TypeOf oFeature Is HoleFeature Then
		'check if its unsuppressed
		If oFeature.Suppressed = False
			'increment one
			i = i + 1
		End If
	End If
	Next
If i > 0
Else
End If
Message 5 of 9
in reply to: mcgyvr
I see now what my issue was and learned a bit from your additions. Thank you for your assistance Sir!
Message 6 of 9
Curtis_Waguespack
Hi @Anonymous,
Additionally you can look at just the holefeatures collection, as in this example.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
i = 0
For Each oHole In ThisDoc.Document.ComponentDefinition.Features.HoleFeatures
	If oHole.suppressed = True Then
	i = i+1
	End If
Next
If i > 0 Then
MessageBox.Show(i & " hole(s) are suppressed", "iLogic")
End If
Message 7 of 9
mcgyvr
in reply to: Curtis_Waguespack
The example from Curtis great/cleaner,etc...
I was just trying to stick with the general flow/layout of the originally posted code just because thats what they seemed to already understand..
Well that and I'm a novice and Curtis can walk all over me in the ilogic world.. Smiley Wink
Message 8 of 9
Curtis_Waguespack
in reply to: mcgyvr
nah, there was nothing wrong at all with your example. I'd already started to post before I noticed your solution, so I just went ahead an added it, but mostly just to add the link to the  Inventor Customization forum:
Message 9 of 9
One other thing I'll add concerning the use of "And" in the conditional statement is that the "And" needs to be inline with the if, and not on a separate line. That was likely the source of the error with "And"
i = 0
	If TypeOf oFeature Is HoleFeature And oFeature.Suppressed = False
		'increment one
		i = i + 1
	End If
Next
If i > 0
Else
End If
In this example I've used a space and underscore after HoleFeature to "wrap" it to the next line, which would work as well.
i = 0
	If TypeOf oFeature Is HoleFeature _
		'increment one
		i = i + 1
	End If
Next
If i > 0
Else
End If
