iLogic - Close all files in the invisible mode
M.iwanow
M.iwanow
Hi All.
Is there a way to close all files open in the invisible mode.
Or I just could clean up inventor memory.
Thaks
For iLogic, you would have to have at least one visible document in order to run the rule.
Dim oApp As Inventor.Application = ThisApplication
Dim oDoc As Document
For Each oDoc In oApp.Documents
	oDoc.Close(TRUE)
Next
This will close all documents in your Inventor session (tested working). I did not find a flag to use to identify Invisible documents.
If you could be sure that the display name of every document was unique, you could compare the DisplayName of the document to the collection ThisApplication.VisibleDocuments and skip the close if it matches. That might look something like this. (Not tested)
Dim oDoc, vDoc As Document
Dim isVisible As Boolean = False
	For Each vDoc In oApp.Documents.VisibleDocuments
		If oDoc.DisplayName.Equals(vDoc.DisplayName) Then
			isVisible = True
		End If
		If Not isVisible Then
			oDoc.Close(True)
		End If
		isVisible = False
	Next
Next
I hope this helps.
M.iwanow
Thanks a lot. It works grate.
