iFeature - rotate
iFeature - rotate
martinhoos
iFeature - rotate
martinhoos
Hello Forum,
i gamble with an iFeature "LongPilot" - it is the end of a tube. the Tube can have the Diameter 10, 12, 16 or 18mm. I placed the LongPilot.IPT. My createt iFeature is asking for a Point and the sketch plane. That will work for tubes that are horizontal or vertical. How can i Change the iFeature that it will without asking take place on an tube that is not horizontal or vertical? Such like the tube at the JPG file.
Hopefully you can understand what i try to say?!
Is anyone out there who can create such an iFeature?
Regards from Germany...
Martin
johnsonshiue
Hi! I believe this has something to do with the sketch constraints you used in the sketch. Instead of using Vertical and Horizontal, you may want to use Perpendicular instead. This will remove the dependency on absolute vertical and horizontal direction which the iFeature cannot control. Could you try it and see if it works better?
Many thanks!
Software Test Engineer
S_May
Hi @martinhoos,
do you still need help?
martinhoos
Thanks for your reply, it is a Long way to understand how the iFeature is working. I fixed the problem.
Regards Martin
martinhoos
Regards Martin
S_May
@martinhoos,
they can show how, so that everything understands
martinhoos
I dont use rotate any more, i create the iFeature referring to the first sketch . Long Story short: Look at the IPT
Regards Martin
