Inventor Forum
IFeature Not Working Correctly
6 REPLIES 6
george.fray
1059 Views, 6 Replies
Hi All,
Having issues when producing an Ifeature into a model. Essentially, I am producing an 'IFeature Model' so that all of our features can be referenced to this part. I have set feature up to include Extend Extrude Cuts.
It works effectively in a simple part but when attempting to use within an Extrusion Design 'Extrude' part, it does not flag any errors but simply doesn't produce part of the IFeature. Very limited experience with IFeatures.
6 REPLIES 6
Jon.Dean
in reply to: george.fray
Hi @george.fray,
Can you explain the difference between the two parts, left and right picture?
Can you also share your iFeature, so we can test the behaviour?
Cheers.
Jon.
Jon Dean
george.fray
in reply to: Jon.Dean
Hi John,
The Differences between the two are the consumed 'extrude' sketches have different geometry also the part I am attempting to place is an IPT. When the IFeature works, its only within the original part. (The 'ifeature body' as i called it.)
Please see the attached files, I am extracting the IFeature from IFeature Body to the 0553 - Asia Affinity SG Production Ipart.
From the looks of it one part is multi-body and the other one isn't.
johnsonshiue
Hi! I think I have found a solution. The issue with the holes (cutouts) not showing up is because of how the workplane was defined. The workplane was based on YZ and the sketch. There is nothing wrong with it. However, the sketch based on the workplane would have a fixed coordinate system. When you insert it to another part, not oriented the same way, the cutouts will not appear properly.
Instead of relying on the second pick to define the cutouts, I use the geometry on "Nemef 9620 F-Face Sketch" to define "Lock Centre Plane" and also edit the coordinate system of "Nemef: 9620 Sash-Lock Thru-Holes" sketch so it is oriented properly relative to other geometry. Please take a look at the attached base part and iFeature. It should work in the iPart now.
Many thanks!
Software Test Engineer
george.fray
in reply to: johnsonshiue
It worked, but as the sketch was incorrect so I went in to amend but I cannot reproduce the result you had, would you mind producing a screencast so I can watch a step by step video?
Thankyou for your time!
 ;D
