IDW
IDW
Message 1 of 18
IDW
You can see in the Finished Drawing (assignment drawing) there are no curves. But in .idw file there are curves.  How to get rid of this?
Replies (17)
Message 2 of 18
mdavis22569
you can click on those items in the idw and turn off the visibility ... however your view is CORRECT ..it's showing the true projected view with the bends
you can see I turned off the bottom ones ... with a click of the mouse
Mike Davis
Message 3 of 18
JDMather
Turn off visibility of Tangen Edges
or
right click and hide.
Message 4 of 18
JDMather
Your Sketch18 has incorrect dimension and is not fully constrained.
Also, Sketches 6, 8, 12, 14 are not fully defined.  You have been instructed here to stop at any time you do not have a fully constrained sketch and ask questions here about how to correct the situation.
With correct dimension - the Sweep does not intersect the square cut.
Message 5 of 18
Thanks for identifying the error. Shown curves in the .idw file also vanished with the dimension correction in Sketch 18.
Message 6 of 18
I don't know how to make Sketch 6 fully constrainted.
Message 7 of 18
JDMather
Drag line endpoint - what do you see?
Turn on Constraint Visibility - what do you see?
Message 8 of 18
If I Drag line endpoint I can see square is moving. If I turn on Constraint Visibility I can see all the constrained that had been made.
Message 9 of 18
JDMather
@Anonymous wrote:
If I Drag line endpoint I can see square is moving. ....
So why does it move?
What is needed to remove the degrees of freedom?
Hint:  Have you started going through these yet?
http://forums.autodesk.com/t5/inventor-general-discussion/skillsusa-document-now-on-screencast/m-p/5...
Message 10 of 18
No I didn't go through the tutorial. I had a glance on that. It seems heavy for the beginners.
Message 11 of 18
JDMather
These are intended for beginners.
10 minutes that will change your life.
Especially time steps 2:06, 6:15, 8:52
Message 12 of 18
Okay I will go through it.
Message 13 of 18
There are 11 videos in the link. I wish to know "Time steps 2:06, 6:15, 8:52" is which video?
Message 14 of 18
JDMather
No.
There is only one video Click Here >>10 Minutes<<Click Here?
Message 15 of 18
Message 16 of 18
Inventor 102 Constrain your Sketches - CFW15 is a single video.
Is any way to download this videos. So that I can save it in my folder and frequently watch it.
Message 17 of 18
Why it showing fully constraint?
Message 18 of 18
JDMather
Did you attach the correct file?
Can you create a Screencast recording?
In the file you attached here - it is not fully constrained.
