An IDW view is showing a second iteration of a part instead of one of each. I have tried turning the visibily on/off in the ipn. I have also toggled the associativity on/off. The view shows the correct image during its preview, but when the view is done being created, it shows the wrong part again.
Not nearly enough information. State what Inventor version you are using, and post the files. Then explain which component is displaying incorrectly and what you would expect to see instead.
I am using Inventor 2012 professional. Specifically, this assembly is essentially a sheet metal box. The front and rear panels are sheet metal parts, the same size, with different punches and holes. Each of these files are part of subassemblies. In one view, instead of showing the front and rear panels in the correct position, the front panel is shown twice, once in its correct position, and once in place of the rear panel. The rest of the assembly in this view is in the correct position, including the other components in the rear panel subassembly. I'm sorry but I cannot post these files on the forum. I can email them to you if you would like to see the problem more closely.
Dan
If you edit the view, ubder the model state tab is the correct member selected?
Do you have SP2 installed?
There was a problem with ipn's in the RTM of 2012
Don't know if it effects your specific problem but needs to be installed regardless
