idw to dwg problems
idw to dwg problems
I have inventor 2014 and I can't save or export a IDW to AutoCAD DWG, I have tried what I saw on other posts but does not works.
The message is: problems encountered while saving the document, I can save as all other formats but not AutoCAD dwg
Replies (11)
Mark.Lancaster
Use the following steps to re-register Autodesk Inventor with your operating system:
1.  Exit Inventor if still running
2a.  Win 8/8.1/10: Select the Windows start button and type CMD (but do not hit an enter)
2b.  Win 7:  Select the Windows start button and type CMD in the search field (but do not hit an enter)
3.  When CMD or command prompt appears in the list, right mouse click and select run as admin
4.  When the command prompt appears, navigate using dos commands to C:\Program Files\Autodesk\Inventor <version>\Bin or where your Inventor.exe is located if you changed the default install location of Inventor.
In this example I'm navigated to my Inventor 2018 (exe) location.
6.  Type Inventor.exe /install.
Wait a few mins and restart Inventor.   At this time you will not see anything occurring.  Don't panic.  Smiley Very Happy  However if you launch Windows task manager you can watch the Inventor.exe process (and see when it ends).
Does that resolve the issue?
Mark Lancaster
Hi Mark,
I've done that and it doesn't work 😞
Mark.Lancaster
@Anonymous
Ok..  No problem..  I wasn't sure what you had found..  For the future just provide a link of what you have found so duplicate info is not provided as a solution  Smiley Wink
Is this the first time you did this (converting) or has this worked in the past?  The reason I'm asking is a Windows update  occurred this week and is impacting legacy versions of Inventor.
Mark Lancaster
Ok, I will do that. Is the first time I try it on 2014, I was using 2017 at my previous job and I never had a problem converting files, but now I have 2014 and for some reason is not working
Mark.Lancaster
@Anonymous
Just to confirm..  At your current place (using Inventor 2014)..  You don't know if this was working or not in the past?   This is the first time you have tried it here (at your current place)?  Have you updated Inventor 2014?  Do you know what updates have been applied to your Inventor 2014?
Mark Lancaster
I am currently using 2014, it was installed 2 months ago (downloaded from Autodesk 2 months ago) and is the first time that I try to export or save as AutoCAD dwg and I do not know if there has been any updates applied to it since then, mi guess is no
Currently I am the only person that uses Inventor (there was one before me) and browsing through the vault there is no record of .idw files but there are dwgs' that on my experience look like they were imported from a idw
Mark.Lancaster
@Anonymous
OK  No problem..  Go to (Inventor) Help/About Inventor and share the Help/About dialog here.  Make sure no sensitive info like you serial # shared.  IF it appears in the dialog, blur it out before posting.  From there we can tell you if its up-to-date or not.
Mark Lancaster
Mark.Lancaster
@Anonymous
Yeah you need to update:
First install this: https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-inventor-2014-service-pack-2.html?v=2014
Then install this: https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-8-for-inventor-2014-service-pack-2.html?v=2014
Let us know if that resolves your issue or not?
Mark Lancaster
thanks @Mark.Lancaster I will contact II so I can get the authorization to do it an report back
Hi @Mark.Lancaster it worked, I updated Inventor and ran the CMD solution again and it worked
