Inventor Forum
IDW - Shaded view visible edge removal
3 REPLIES 3
336 Views, 3 Replies
Hi All,
How to remove all Visible edges in Shaded View of IDW? We use the sheet for
presentation purposes and the image is a lot better than save as bmp.
3 REPLIES 3
tools > options > display > Under shaded display model active uncheck edge display..
Think if you remove lines in tools> options> display>. They will only be removed from the ipt.
You have to select each individual line on the shaded view in the idw. and make them invisible. can be a bit time consuming.
Adrian.
It actually helps in the IDW environment also, but
the outline has to be manually made invisible.
This would be an easy task with a
window select option...(!)
Peer
Think
Adrian.
