Inventor Forum
idw's efficiency
1 REPLY 1
175 Views, 1 Reply
idw's efficiency
I have part A.ipt,I use it creat drawing A.idw ,they are in the same
directory.
as I will design part B.ipt,and parts A¡¢B similarity£¬in order to improve
design efficiency,I do that:
I put A.ipt¡¢A.idw two files to other directory,rename to B.ipt¡¢
B.idw,then£¬I can edit B.ipt,but B.idw's part is A.ipt,it no change .how can
I make drawing B.idw associate to B.ipt£¿
thanks.
idw's efficiency
directory.
thanks.
1 REPLY 1
You can read up on the capabilities of the Design Assistant. A simple and quick workaround is to close all the files, using Windows Explorer rename A.ipt A.tmp, open B.idw and when it asks for the location of A.ipt choose B.ipt, then save B.idw. Now rename A.tmp back to a.ipt.
I would recommend you get familiar with the Design Assistant so you don't have to do those types of file system operations.
