IDW Isometric Slice and Dimension
Hi, I am trying to create this layout in idw. it's an Isometric drawing with a quarter slice in it, as far as I can tell this is the best way to layout this part. It's the top left part in the attached image, named Base. I've also included the ipt. This is my assignment for class, any info on how to create this would be much appreciated. Thank You
Well I managed to create the danged view by voiding out the quarter section in the the ipt and save as. But now it's dimensioning perspectively, rather than actually, as you can see in the image. It should be an 1/8th inch. Smiley Sad
mdavis22569
I did it by cutting a section in the base view and then doing an iso off of the section ... then I moved the other views off of the sheet
Mike Davis
JDMather
Uhmm, what is the correct tap drill size of a 1/4-20 UNC hole?
What will happen if you try to insert a 1/4-20 UNC fastener into a Ø1/4 hole?
Hey awesome, thank you! I actually created that earlier but never even realized I could simply pull the other views of the sheet! Thank you for helping
