I would like to streamline a drawing set to change model states of several parts and sub assemblies according to the model state of the main assembly. I already use linked model states and states with same name, but since a model can be any state at any time, the drawings become static.
Model state snippets seem to include most needed applications for part and assembly.
But for drawings I can only find 'read only' actions.
Is there a way to force a model state change on a view? Right now I have to manually check each view on each drawing.
Am I in the wrong work flow path, and model states are meant only for production steps and not for model variants?
Solved by pcrawley. Go to Solution.
There are some propeller heads over here who may be able to help:
Inventor iLogic and VB.net Forum - Autodesk Community
