IDW balloon background color
Message 1 of 8
Can anyone tell me how to change IDW balloon background color? Example- circle, within circle behind part number and make color different from sheet color.
Replies (7)
Message 2 of 8
mdavis22569
You can change your sheet backgrounds, but I don't see how you'd be able to change the background on default balloons.
You might be able to make it a balloon sketch symbol that you would have to insert for each item...
Mike Davis
Message 3 of 8
Hoped to have more control than that, but that will work.
Message 4 of 8
Mark.Lancaster
To add mdavis22569 posting..
If you are creating a multi-sheet single drawing file in Inventor, all the sheets have the same color.  You are unable to assign different colors to each sheets unless each sheet is its own drawing file.
Mark Lancaster
Message 5 of 8
I need to have one type of balloon to be yellow in the balloon background itself and then red in another balloon on the same sheet. Was hoping for more flexibility to change balloon style for different selection types. Like a hatch color option on the balloon style for fill in the balloon itself. thanks for trying
Message 6 of 8
mpatchus
Well you could create a custom symbol (or multiple symbols in your case), and manually override the balloon with the custom symbols.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 7 of 8
thank you
Message 8 of 8
tim.schroeder3K47N
anyway to make the balloons stretchable with text like the default balloons?
