Inventor Forum
IDF import
2 REPLIES 2
402 Views, 2 Replies
IDF import
I have some IDF files who making problems in some versions of inventor. By downloading newest free trail version (Build 138, Release 2016 RTM -Date: Fri 02/27/2015) the files are correct and board outline with drills have correct size.
By importing it with "newer" version (Build 210, Release 2016 SP1 - Date: tue 10/13/2015) some holes are missing and many sizes are wrong.
Is there some way to "downgrade" the installed version to the demo version to get an working IDF import?
Is this known and is there a bug fix comming soon?
Thanks for help
Tags (1)
2 REPLIES 2
mcgyvr
Can you post the idf files and an image (from your PCB program maybe) showing how everything "should" look..
Also include the name/version of the PCB program you are using.
You should be able to uninstall SP1 if needed..
But by providing as much information as you can will help them fix any problems quicker/easier (if there are some)
Hi Support Team, I have to discuss with customer to send IDF-data to you. In the screenshot you can see the different drills (same file in full version and demo version). The output software is PCB-Investigator (download newest version: http://www.easylogix.de/download/pcbinvestigator_demo_setup_70.zip ) The idf file works well in SolidWorks, only in the ?newest? version of Inventor the drills are missing/wrong sized. Viele Gr??e / Best Regards Fabio Gruberwww.easyLogix.de www.pcb-investigator.com mailto:fabio.gruber@easyLogix.de Tel. +49 (0)941 604889718 Fax +49 (0)941 604889717 Schindler & Schill GmbH Bruderw?hrdstra?e 15b 93055 Regensburg Germany Rechtsform: GmbH Sitz des Unternehmens: Bruderw?hrdstr. 15b, D-93055 Regensburg AG Regensburg: HRB 11047 Gesch?ftsf?hrung: G?nther Schindler Diese E-Mail enth?lt vertrauliche und/oder rechtlich gesch?tzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrt?mlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet. This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail by mistake) please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. _____ Hi a1_2016, mcgyvr (Mentor) posted a new comment in Inventor General Discussion on 12-01-2015 07:34 AM : _____ Re: IDF import Can you post the idf files and an image (from your PCB program maybe) showing how everything "should" look.. Also include the name/version of the PCB program you are using. You should be able to uninstall SP1 if needed.. But by providing as much information as you can will help them fix any problems quicker/easier (if there are some) Reply | Accept as Solution | Give Kudos _____ Autodesk Community sent this message to fabio.gruber@easylogix.de . You are receiving this email because a new message matches your subscription to a topic. To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe .
