Ideas or examples needed to draw helical rotor
Dhegderx
Message 1 of 11
Dhegderx
WhatsApp Image 2022-08-08 at 2.07.35 PM.jpegWhatsApp Image 2022-08-08 at 2.07.26 PM.jpeg  WhatsApp Image 2022-08-08 at 2.07.20 PM.jpeg
Hi Experts,
The above part is from a progressive cavity pump and I am struggling to draw it. The total length of the part is 1830mm, the length and diameter of the hub is 143.50mm and 120mm respectively. The diameter of the coil is roughly around 73 mm on average  and oscillates between 71- 78mm.
Can anyone please guide or model something like this so that i can visualize how to draw this.
Replies (10)
Message 2 of 11
blandb
What version are you running?
Autodesk Certified Professional
Message 3 of 11
blandb
Attached is a '22 very quick example. I imagine there will be others as well.
Message 4 of 11
Frederick_Law
Draw is easy.
Draw correctly is not.
Message 5 of 11
JonathanKruger
I don't know why but I imagined your answer being said by Yoda which made me me laugh, but I assume there is some "design" that you need to understand in order to draw this correctly?
I would be interested to understand but have no experience with these kind of pump designs.
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
Message 6 of 11
johnsonshiue
Hi Folks,
I could be wrong but I suspect this is something Solid Sweep can help.
Many thanks!
Software Test Engineer
Message 7 of 11
Dhegderx
Inventor 2023
Message 8 of 11
SBix26
Here's my attempt with Inventor 2023.  I don't have all the parameters, of course, but these can be adjusted.  The diameter of the helical section varies between 78mm and 71mm with each turn-- not sure if that's what you meant or not, but I achieved that with a Loft over one pitch of the screw, then patterned that one.
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
Message 9 of 11
Dhegderx
Excellent more  precise  and exactly what I was looking for thanks.
Message 10 of 11
SBix26
More precise, perhaps; but a Loft feature is rarely well enough defined to use for a machined part.  If you need this for appearance, or to make a drawing where the precise definition of the part is given by text, it may be adequate.  But it certainly is not sufficient as the definition for machining a precision part like this.  If such a model is needed, I have no good ideas at this point for how to create it...
Sam B
Message 11 of 11
Frederick_Law
Talk like Yoda, I do.
Sometime
Not knowing the application or mating part, it'll be difficult to make it correct.
Since OP said it's progressive pump, it'll have tight fit depends on medium it's pumping.
Some screw pump has increasing/decreasing pitch/diameter.
If this is a good sample, 3D scan it.
If its worn out and repaired, good luck.
