Inventor Forum
iCopy File Management
1 REPLY 1
HogueOne
110 Views, 1 Reply
Hey there. Thanks in advance for checking this post.
I'm trying to use iCopy to generate ACM panel assemblies with framework for building facades. The problem I'm experiencing is the tool forces me to uncheck the "Reuse Standard Content and Factory Parts" every time I make a new panel so that the frame members resize to the skeleton the layout part is adapting to. Is there a way to disable this by default, or perhaps a better method?
Also, when prompted to change file names it automatically appends a "1" on the end of each file, after the suffix you designate. I don't want to pattern the iCopy assembly, I just want the suffix to increase (eg: 001, 002, 003) every time I place a new iCopy assembly. What is the best way to approach this?
Thanks again.
Labels (6)
1 REPLY 1
johnsonshiue
in reply to: HogueOne
Hi! I am sorry that I am not aware of Inventor workflows to fulfill the requests unfortunately.
Many thanks!
Software Test Engineer
Technology Administrators
