Inventor Forum
Icon-New -Aplication Menu
9 REPLIES 9
Message 1 of 10
dusan.naus.trz
478 Views, 9 Replies
Icon = New = contains a drop-down list = Assembly, Drawing, Part, Presentation
1. Where is the option to set these templates?
2. What are templates?
Video in the attachment
9 REPLIES 9
Message 2 of 10
They are Templates in "Template Folder".
In Application Option and Project File.
They're file with: Standard.*
In fact some internal commands will use them and user can't change it.
So it's best to save templates in those name.
Message 3 of 10
My project file does not contain the name Standard. Please show me the path to these files.
Message 4 of 10
Copy your templates and rename them Standard.
Message 5 of 10
Yes it works. Thank you for the explanation. This means I have to rename all the templates. That's pretty limiting. Is there a list of features that depend on a template named Standard? I used my name according to the language Standard is our name = Norma. So I was using it wrong. People have their own Design Data and their own Templates, this change probably happened in some version.
Another question, but also about the template.
I use mm and this setting does not affect me in any way. What is the Configure Default Template button for? What does this button do?
Message 6 of 10
Not changed since R1.
Everyone creating their own template not knowing IV use "Standard".
That's why people keep complaining file don't use their templates.
The "Norm" was changed:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-1AB52C58-D318-4250-A674-44796198D7FD
Not sure what the Default do.
If you use mm, set it to mm.  Just in case.
When IV cannot find Standard, it'll use a internal template.
Message 7 of 10
My Path
C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates
Which template from which folder does the system prioritize?
Message 8 of 10
I understand. All templates must be named Standard. Thank you very much for your explanation and patience.
Message 9 of 10
My Path
It doesn't look into folders.
Put all Standard.* in \Templates
Message 10 of 10
You are right, all countries have the same names for templates. 🙂
https://www.youtube.com/watch?v=w7S_rchlZw8
