iAssembly not Saving
baran-ersoy
Observer Observer
baran-ersoy
Observer
Observer
Hello together,
First of all, this is my first Post here and English is not my native Language, so please do not wonder if my explanation is not that understandable!
So i created 2 iParts with each 3 Different Versions (Different Lengths) and i somehow cant create an iAssembly where all 3 Versions work together as they should. After Putting it all together, saving and close to open it again i get this error every time. From my understanding it says that the Parts have different References. The 2 iParts have each a Chart in them, where all 3 Versions are saved. The iParts itself work without Porblems, even after closing and opening again. But every Time i close the iAssembly (with Saving before i close) and open it to try changing the Versions, i get an Error where i have to do the Steps in the Video. Most of the times (not always) it afterwards works and i can change the iParts in the Chart. Sometimes i also get an Error where only one of the two iParts change and the other one stays stuck and does not Change between all 3 Versions. Thats when i have to close the Tab (without saving of course) and open it to try again.
Can someone help me please?
(view in My Videos)
johnsonshiue
Hi Baran,
Please don't worry about the language. Your English is perfect. Based on the view, I think either are are duplicate files stored in different folders or some files cannot be found during the member elaboration process. If possible, please share the iam and ipt files with me directly at [email protected]. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
