iAssembly linking parameters only to Base iPart
Hello all,
I am trying to build a sheet metal panel assembly that will add clips to the holes at the sides of the panel.
I have created my panel as an iPart. The parameters I need to use are Width, Height and I have some formulas to add the hole patterns down the sides based on the height and a max hole spacing. Now when I create my iAssembly i add the ipart table and i added the hole formula parameters. Problem being when i switch between my iPart panels the formula parameter will not update to the formula in the different iparts. It remains linked to the base ipart. I am hoping that the clips will be added based on the changing hole formulas from each variation of my ipart.
A little hard to explain, I have attached my iassem, ipart and the clip.
