Close Loop
Close Loop
lkirit2000
Advisor Advisor
Message 1 of 8
Close Loop
lkirit2000
Please see the attached profile sketch and images around the circle, when I tried to extrude solid extrude is success, error message shows open loop.
In the sketch environment I right click and and tried to fix the close loop, again error message pop up due to constraint.
( See the attached image ) and it is repeating ?
How to fix this issue
Rgds
Replies (7)
Message 2 of 8
CadManagerMoffatNZ
Try changing the project geometry (yellow) lines to construction
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
Message 3 of 8
johnsonshiue
Hi! This is an interesting issue. I think the problem with the profile is that it is indeed open. Edit the sketch and zoom in to the vertical line with a dimension of 8.85 (upper left). The bottom of the line is actually not constrained to anything. You need to delete the dimension and add a coincident constraint between the line and the arc. Then the profile will be closed.
Many thanks!
Software Test Engineer
Message 4 of 8
lkirit2000
Hi Johnson,
Appreciate the quick response !
Thanks the problem solved.
I just wonder the I tried the close loop feature to fix the issue, it says there is a open loop but it hasn't pointed out or highlight which location !
The issue some thing like in a complex sketch will take a long time to zoom and check.
Rgds
Message 5 of 8
kelly.young
Autodesk Support
Autodesk Support
Hello @lkirit2000 you have a situation where it is almost over-constrained to where the set dimensions don't allow for the gap to be closed. Here is a screencast showing how to edit the setup and close the profile.
Please select the Accept Solution button if a post solves your issue or answers your question.
Message 6 of 8
lkirit2000
Hi kelly,
Thanks for your explanation !
Great !!
Rgds
Message 7 of 8
harrelsontrumpets
The over constraint problem with Autodesk products makes them extremely difficult to use. I can design 10 times faster in Rhinoceros because the software doesn't add junk like this to my drawings. I am literally struggling on most organic designs in Inventor because of this persistent and completely unnecessary constraint issue.
Message 8 of 8
johnsonshiue
Hi! If possible, please share an example here or start a new thread. I am not sure I understand the issue from your brief description.
Many thanks!
