Hi! Please note that iAssembly/iPart were designed to create library components (self-sustained, independent, and totally driven by the table). The notion of on-the-fly configuration contradicts the original design intent.
I suspect you should use iLogic rule to configure one variation (drive parameters at all levels). Once you are happy with one variation, you can use iLogic Design Copy to spawn the version. Then you keep working on another version.
It allows you to have infinite permutation without the need to capture it on a table.
Many thanks!
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
