IAssembly/IPart BOM is not updating per Model Member
DougKCXSML
DougKCXSML
I created the IParts and an IAssembly for a wooden display unit.  All the IParts seem to update correctly.  The IAssembly seems to update correctly.  I created the BOM for the first member(default).  When I switch the Model Member the BOM is updated but with now information.
I'm thinking there is something simple I am missing.
I'm using 2023.
CGBenner
@DougKCXSML
Welcome to the forum.  Is it possible for you to share a file that others can look at to see if there is an obvious solution?
Chris Benner
DougKCXSML
Sure, what is needed?
I assume everyone can see the images?
johnsonshiue
Hi! Please find all the iam, ipt, and idw files using Pack&Go and zip them up. Attach the zip file here.
Many thanks!
Software Test Engineer
DougKCXSML
Roger that.  I added the zip file.
Thanks for helping.
johnsonshiue
Hi Doug,
Many thanks for sharing the files! I am on 2023.5 update. I cannot seem to reproduce the behavior. I vaguely remember seeing the behavior before. Please install 2023.5 and report back the findings.
Thanks again!
CGBenner
@DougKCXSML Hello, do you still need help with this question?
Chris Benner
