Inventor Forum
IAM reader
19 REPLIES 19
Message 1 of 20
eleblanc
859 Views, 19 Replies
IAM reader
Is there such a software from autodesk that would open iam files and let the user to take measurement only?
Eric
19 REPLIES 19
Message 2 of 20
JDMather
in reply to: eleblanc
Can you request a *.dwf or *.dwfx rather than an iam?
Message 3 of 20
eleblanc
in reply to: JDMather
No, it would be too much trouble to save a dwf each time we change something to a iam. I'd like my shop foreman to be able to open idw (containing layout with iam) or directly the iam to go take mesearment that could be missing on idw. No edit no save. Just open take the dimension and close. I was suggested to use inventor LT, but it will not open anything with a reference to a IAM.
Unless there aren't a easy solution, It look like i will have to get a complete Inventor license for the shop foreman, so he can retreive a dimension in the event the inventor operator is away! hard to beleive!
Message 4 of 20
JDMather
Free Inventor View and fully dimension the drawings.
Inventor View will open Inventor files. http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=18585712
I don't think it has a measure tool.
another option might be Inventor Fusion (for ipt and iam files).  http://labs.autodesk.com
Message 5 of 20
mcgyvr
I would never use Fusion for this (neat suggestion though).. Why.. Because they can MODIFY files.. BAD..BAD Thing
Message 6 of 20
eleblanc
Yes bad idea. I've just lunch fusion 2012 and tried to open a iam, but the assembly was probably way too big. still loading after 5 minute. And Fusion comes with inventor, so you cannot install fusion as stand alone on a other station.
Message 7 of 20
eleblanc
Funny enough i was told the 3D version of this will do it! Yep not a autodesk product but oracle. But expensive.
http://www.oracle.com/us/products/applications/autoVue/autovue-3d-professional-advanced/index.html
I've yet to give it a try tho.
Message 8 of 20
JDMather
in reply to: mcgyvr
Fusion doesn't save Inventor format files.
Message 9 of 20
mcgyvr
Ahh.. I was not aware of that.. (I never use fusion obviously)..
Message 10 of 20
JDMather
in reply to: mcgyvr
...but it does save as a dwg that Inventor somehow recognizes changes from the ipt.
Change Manager can be used to compare the Fusion changes to the Inventor original and accept or decline the changes.  I have seen shop floor changes made that are not communicated to engineering and therefore the documentation doesn't match the shipped part.  Maybe this would be a way to help communicate shop-floor changes back to engineering to ensure that documention matches the actual parts.  Of course everyone needs to work together on this.
Message 11 of 20
Hi eleblanc,
Understanding that you said DWF would not work for you, I just wanted to point out that you can set up a DWF publish task using the Task Schedulaer. This can be set up to run every evening so that any changes you make today are published out to a directory of your choosing for the shop to look at tomorrow.
If that still won't work, then the Vault products might be worth looking at, if they fit your setup.
I hope this helps.
Curtis
Message 12 of 20
jletcher
We have a computer in the shop for this it has a seat of inventor but in the network permissions that computer can only do a saveas on the desktop they cannot save to the network. This way they can do anything they want but save it back to the real file..
Message 13 of 20
eleblanc
in reply to: jletcher
Yeah, obviously i'm trying to avoid a second Inventor license for doing that only and only about half hour a day. A second license mean double subscription every year. For a small shop double is alot.
I was hoping that inventor LT would allow to open idw with layout of IAM. But it does not.
Message 14 of 20
I hope this helps.
Curtis
Vault product? can you elaborate?
Message 15 of 20
Hi eleblanc,
I'm really not the right person to talk to about Vault, as I don't stay up on all of the details. But if you feel that the only solution is to spend some money then it might be worth looking at Vault Workgroup, which allows Non-CAD users to view your engineering files securely. There's a lot more to it than that as well. Attached is a basic Vault brochure, but you'll probably want to speak with your reseller for more information.
I hope this helps.
Curtis
Message 16 of 20
Well looks like edrawing from SW can open assemblies and measure from it.!
Message 17 of 20
ampster40
I just installed eDrawings 2012 (x64 edition) on Win7/64 that has Inventor 2011 on it.  Just the "plain" version of eDrawings, not the Professional version.
I am not able to open an Inventor assy file.
What did you do differently?
TIA
Message 18 of 20
jletcher
in reply to: ampster40
I think it only opens Solid Works file he was just letting Autodesk know how they are still behind the times...
And if they stop waisting time on crappy Interfaces they may be able to make it so Inentor View measure...
Message 19 of 20
eleblanc
You are correct. edrawing can open native solidworks part or assembly and measure. Autodesk as nothing equivalent, and i'm being ask to get a full inventor license for that. Having to maintain a license to measure assemblies is very expensive.
Sadly even inventor view can't handle large assemblies.
Message 20 of 20
mrattray
I would seriously consider Curtis's suggestion of using task scheduler to automatically export dwf's.
Mike (not Matt) Rattray
