IAM (assembly) inside IPT (parts) file?
I am quite new to Inventor (currently using the 2017 version). I usually do all my work in Revit.
The company that i'm working for has a BIM subcontractor that is struggling with the use of Inventor.
Now they've sent us their ipt-file so that we could troubleshoot it. See picture below. There is an iam-file (assembly) within the ipt-file. Is this normal?
(if anyone is interested, I could provide the ipt-file for further inspection)
Sigurd Bekkevold
iam file inside an ipt file.PNGProject Engineer
S_May
HI @Anonymous,
Iam = assembly
Ipt = component
If you want to clean work, then you need from the other employees also clean ipt (models) and iam (assembly)
Please upload your Group Smiley Happy
Thanks for the fast reply.
By group, do you mean the ipt-file?
I'm not familiar with the term...
S_May
IAM + IPT Smiley Happy as ZIP / RAR
S_May
Hi @Anonymous,
So should look a simple assembly:
2017-08-08 08_38_46-Autodesk Inventor 2016 - [366807_Dachgerüst_komplett_B-Seite_links_519224.iam].png
salariua
What you see is normal.
That assembly is added as derived model. It is a common technique to simplify models and to provide single item (part, *.ipt extension) rather than a large number of items (assembly, *.iam extension)
Edit:
here are some resources.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
youtube videos.
https://www.youtube.com/watch?v=Ukvt4uuhxK0
or any of these:
https://www.google.co.uk/search?q=inventor+derive+shrinkwrap+substitute&num=100&rlz=1C1CHBF_en-GBGB7...
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
