Inventor Forum
I need your help!
22 REPLIES 22
Message 1 of 23
st32-22
1008 Views, 22 Replies
I need your help!
Exam is tomorrow I got 2 more examples, did I do it good?
22 REPLIES 22
Message 2 of 23
CCarreiras
in reply to: st32-22
I would fail your test.... there are so many dimensions needed.....
If i manually drag the lines, look what happens..... that can happend
CCarreiras
Message 3 of 23
st32-22
in reply to: CCarreiras
I don't get it, I'm sorry! 😥
Message 4 of 23
st32-22
Isn't the final product what matters it looks fine
Message 5 of 23
JDMather
@st32-22
Do you see in @CCarreiras image lines that should be constrained vertically or horizontally that are not?
Message 6 of 23
st32-22
in reply to: JDMather
I see, but still don't understand 😣
Message 7 of 23
JDMather
Well, add the missing Horizontal and Vertical constraints.
Message 8 of 23
CCarreiras
Doesnt look fine... is missing something here:
Well, in mechanical design, is not enough to look fine, the important is to have the correct information, unless you are studing marketing or design...
CCarreiras
Message 9 of 23
CCarreiras
Now it's fine.
CCarreiras
Message 10 of 23
st32-22
Oh, that looks so hard! I'm gonna send you 2nd example.
Message 11 of 23
JDMather
@st32-22
Edit Sketch1.
Click and drag some of the lines.
See any unexpected behavior (like lines without Horizontal or Vertical constraints)?
Message 12 of 23
swalton
No.
Making sure that the model is accurate, fully-dimensioned, and manufacturable are critical skills to be a successful designer.  Skipping those steps may make a nice picture, but cost time, money or frustration from other CAD users, the manufacturing floor, or the project management team.
Everything that the operator does from the first feature in a part through an assembly, and the final 2d or 3d documentation is dependent on the previous steps.  If the first few steps have bad or unstable data, then everything that follows is unstable, untrustworthy, or just plain wrong.  The House of Cards essay by Walt Jaquith is directed more at assembly issues, but the get-the-basics-right theme is important.  https://forums.autodesk.com/t5/inventor-forum/is-inventor-really-useful/m-p/1332818/highlight/true#M...1
Steve Walton
Inventor 2023
Vault Professional 2023
Message 13 of 23
st32-22
I don't get it why are lines wrong when they made my final product look good?
Message 14 of 23
st32-22
in reply to: swalton
But I just need to pass the exam, I don't wanna be programmer it's just a random subject.
Message 15 of 23
st32-22
I mean not programmer modeller or whatever
Message 16 of 23
JDMather
SpaceX Starship super-heavy booster and launch pad "looked fine", till they tried to actually use it for it's intended purpose. Crash and burn.  Do you want to repeat the class?
Message 17 of 23
CCarreiras
OK, i think you're fine, i think you have just enough to pass.
Anyway, you will not have much time to learn this properly, but as you said, you just want the minimum skill to pass... so, youre good to go.
Good luck.
CCarreiras
Message 18 of 23
st32-22
Thanks, yeah I don't have much time the exam is in 20 hours
Message 19 of 23
JDMather
@st32-22
(one possible) Solution Key...
Message 20 of 23
st32-22
Wow, you are pro!
Technology Administrators
