Inventor Forum
I need help with an Animation
3 REPLIES 3
337 Views, 3 Replies
Hi I'm currently working on a project for an internship at an engineering company and hit a wall on the animation. I am trying to animate moving wall panels to fold and open on a rail and have no idea how to animate it, all the parts move and the panels do fold and open on the rail when I control them with my mouse, I attached a picture of my assembly and would appreciate whatever help I can get. Keep in mind I'm still in high school and learned most of Inventor by myself so I may have no idea of some of the things you suggest, try to keep the answers as simple as possible for my sake.
Also I used those weird colors on the walls for contrast to help you better distinguish the panels and rail from the walls.
3 REPLIES 3
blair
Look at "Drive Contraints"  RMB on the constraint and select "Drive"
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
The thing is I have so many constraints that I don't know which one to
select that option on. Could you suggest a constraint that could make the animation work? I constrained all the panels to each other using hinges and then placed a roller in the middle of the panels and connected the rollers to the rail.
JDMather
Have you gone through the Inventor Studio tutorials?
I would not use any Contact Sets for this.
Place directed angle constraints between the panels.
Give the angle a parameter name and then use this for each constraint.
Go to Environments>Inventor Studio and Animate Parameter.  There is an example in the Tutorials.
