i cant offset the offseted profile
1151303381
1151303381
Community Visitor
Community Visitor
im trying to create offset of airfoil, however i cant delete the original profile and keep the offseted profile. second i also cant offset or select the profile that has been offseted.
inventor 2023
Community Visitor
Community Visitor
here is the file
CCarreiras
Hi!
If you delete the source, the offset will be deleted also...
Turn the source into construction geometry.
Create a second offset from the source geometry instead.
CCarreiras
johnsonshiue
Hi! Indeed, it is a limitation that an offset spline curve cannot be offset again. You may right-click on the offset curve -> Convert to Spline. Then you can offset it again. However, the associativity to the original spline will be broken.
Another workflow to keep the associativity is to create a surface. Instead of using Offset Curve, you can extrude the spline as a surface. Then use Thicken/Offset to create the offset surfaces. Lastly project the surface edges to a new sketch.
Many thanks!
Software Test Engineer
