Message 1 of 8
- Mute
- Permalink
- Report
Why?
Right-clicking and using the "Close Loop" command will NOT let me select the sketch blocks.
Why?
Still there in IN2019...
Old annoying bug - it seems that a part of a sketch block cannot be part of a region. A region must be fully enclosed by either a sketch block, or only geometry created in the sketch.
To get around this you need to trace the ekstra geometry on top of the sketch block to close the region. (Yes, double lines ) Here you need to be careful so the end points are coincident to sketch geometry not to the block, if not the region still isn't valid.
Torbjørn
Inventor 2017.4
Hi @cyberider,
Like @torbjorn_heglum2 said it's an annoying bug.
You have created those rectangles and Circles within a Sketch Block.
You connected it with lines.
At this moment Inventor doesn't see a closed loop between the lines and the sketch blocks.
If my post answers your question Please use
.Accept as Solution &
Kudos This helps everyone find answers more quickly!
Hi! Yes, this is a very annoying behavior, I agree. Inventor sketch profile recognition is constraint based, not geometry based. Currently, the behavior is indeed a limitation. We are aware of the deficiency and we are working on a solution for future releases.
Many thank!
Hi Johnson, you say "Inventor sketch profile recognition is constraint based, not geometry based."
However all the curves in my examples are constrained to each other. It is a closed profile loop but Inventor doesn't recognize it as a closed loop and will not let you use the Closed Loop tool to force itself to recognize all the constrained curves as a closed loop.
Hi! When there are blocks in a sketch, the entire block is considered a rigid set. Although the additional geometry forms a closed loop, Inventor still does not recognize it unfortunately. I am using your case to test our new profile solution. I will let you know what I find.
Many thanks!
Hi! I try this particular case using our internal sketch profile build. The profiles are properly recognized. Unfortunately, the ability to do that is limited to future release, the the existing releases.
Many thanks!
