I try to change the state of a part from Reference to normal inside of a BOM window and that is automatic change back to Reference. I can only manage to change the state from tree window. Why is that? I don't have this issue with Inventor 2023.
After update to 2024 have issues with Ilogic constrains that i solve and now i find that many random parts appears as Reference instead as Normal. In complicate and big Assembly how to be sure that the BOM have all parts for construction and don't have many parts hided because of this issue?
It exists a way to correct it all massive without to search one by one in tree window?
In Ilogic when i suppress a part that affects the BOM structure of it?
Solved by A.Acheson. Go to Solution.
In a BOM with over of 30 sub assembly's inside of other sub assembly's and over a 2000 parts in total how to find witch part is converted to Reference at they own? For now i had to search one by one all the parts.... And i don't know what is going wrong in Inventor 2024. My BOM lists is ok in Previous version 2023.
Hi @stamy1
The browser bom structure sets the occurrence from normal to reference in the context of that assembly. The BOM editor is a direct link to the document settings of that specific part/assembly.
It is true that the occurrence should not be set to reference if you have not done so, this would be a bug if this is true. Would another person have set that in the assembly?
If you want to batch set this you can do so with some ilogic code to avoid the one by one search. Here is an article for working with assemblies using code
Sub Main
Dim assyDoc As AssemblyDocument = ThisDoc.Document
' Call the function that does the recursion.
TraverseAssembly(assyDoc.ComponentDefinition.Occurrences)
End Sub
Private Sub TraverseAssembly(occurrences As ComponentOccurrences)
' Iterate through all of the occurrence in this collection. This
' represents the occurrences at the top level of an assembly.
For Each occ As ComponentOccurrence In occurrences
' Set the Occurrence BOM Structure.
occ.BOMStructure = BOMStructureEnum.kNormalBOMStructure
' Check to see if this occurrence represents a subassembly
' and recursively call this function to traverse through it.
If occ.DefinitionDocumentType = kAssemblyDocumentObject Then
TraverseAssembly(occ.SubOccurrences)
End If
Next
End Sub
Thanks a lot, That helps me to not searching one by one manually. What happens with parts mark as purchasing?
I think is a bug and also I want to have a confirmation from another user! So please reply to us if anyone has seen that!
Hi @stamy1
I used the incorrect BOMStructureEnum it should look for Reference and change to Default. Normal is only available from within the document.
Updated Code.
Sub Main Dim assyDoc As AssemblyDocument = ThisDoc.Document ' Call the function that does the recursion. TraverseAssembly(assyDoc.ComponentDefinition.Occurrences) End Sub Private Sub TraverseAssembly(occurrences As ComponentOccurrences) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. For Each occ As ComponentOccurrence In occurrences 'Check if BOM Structure set to reference If occ.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then ' Set the Occurrence BOM Structure to default. occ.BOMStructure = BOMStructureEnum.kDefaultBOMStructure End If ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If occ.DefinitionDocumentType = kAssemblyDocumentObject Then TraverseAssembly(occ.SubOccurrences) End If Next End Sub
Hi @stamy1
I am not entirely sure what is happening here.
It may not like the k...object so try putting in DocumentTypeEnum before the object type.
If occ.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then TraverseAssembly(occ.SubOccurrences) End If
Can you share the more info of that error message?
After the change in line 21 still get the same error: Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Hi @stamy1
Have you any suppressed occurrences? Any empty assemblies?
Can you check the code in another assembly?
If you know which line it fails on, wrap it in a try catch statement and use a logger line to display the occurrence this way you can narrow down to the exact occurence failing.
Try
'Enter line to test
Logger.Info("Ok: " & occ.Name)
Catch
Logger.Info("Fails: " & occ.Name)
End Try
My code suppresses and unsuppresses parts and assemblies in order to make the design according to the order that we got.
Inventor 2023 changed the BOM structure when i suppressed a part or assembly as "reference" and when I unsuppressed, it changed back to "normal".
In Inventor 2024 it changes the structure to "reference" but in never reverts it back to normal when I unsuppress it and I have to do it manually. I have realized that this is happening to assemblies that are imported for the first time in Inventor 2024 from Inventor 2023.
Another "bug" is that in the 2024 version when, in the BOM window, when I change the structure from "reference" to "normal" it doesn't register and it goes back to reference without ever having saved the change. Only way to change it is from the file browser one by one, which is time-consuming.
Hi @stamy1 that definitely is an issue that behavior you describe.
Although the BOM not allowing changing reference to normal that seems like normal behavior (also in Inventor 2020 & 2022 when the occurrence has a local override.. It will change and change back like an elastic. It really should give a warning of what the behavior is because it can be confusing.
Here is an updated code to deal with read only assemblies and suppressed parts/assemblies.
Sub Main
End Sub
Try
'Logger.Info("Ok: " & occ.Name)
If occ.BOMStructure = BOMStructureEnum.kReferenceBOMStructure AndAlso Not occ.Suppressed Then
End If
If occ.DefinitionDocumentType = kAssemblyDocumentObject AndAlso Not occ.Suppressed AndAlso occ.Definition.Document.IsModifiable Then
End If
Catch ex As Exception
'Logger.Info("Fails: " & occ.Name)
End Try
Next
End Sub
