I have I-Part/I-Assembly with many Factory Members. I can open the Factory Member Part/Assembly Files by browsing to their location.
But this is a cumbersome task to search for a particular member when they are a lot of them with similar part numbers.
Is there as way to open Factory Member File (Instead of the Master file which generates those members) from the User Assembly (Assembly which uses the I-Part/I-Assembly).
Thanks and Regards,
Jiten
Thanks and Regards,
Jiten
Jitenkumar
If you open a member from an assembly you get the iPart or iAssembly factory. If you want the given member then you have to manually open it by navigating to the actual member. It is set up that way because the factory is always the controlling file.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Jitenkumar
Mark Lancaster
Thank You Mark.
It would have been good to have that option though.
if anyone has an API for this purpose, Please post it here.
JIten
Thank You Mark.
JIten
Ok Did a little Internet search/Learning. Here it is.
Sub openselected()
Dim oDoc As Document
Dim obj As Object
Set obj = ThisApplication.ActiveDocument.SelectSet.Item(1)
If (TypeOf obj Is ComponentOccurrence) Then
Dim occ As ComponentOccurrence
Set occ = obj
End If
Set oDoc = ThisApplication.Documents.Open(occ.Definition.Document.Fullfilename, True)
oDoc.Activate
End Sub
Sub openselected()
Dim obj As Object
Set occ = obj
End If
oDoc.Activate
End Sub
