I created this hopper (I attached the file) a few months back and now it needs to be welded together. I created it as one whole part, however when manufacturing this it needs to be cut in sections so they can fabricate and weld each section together. I am unsure if its possible to get a flat patter for each section to get cut before we assembly this, or if I will need to recreate each individual part to do this. Does anyone know a way to accomplish this without remaking it?
Solved by JDMather. Go to Solution.
It would really help if you shared the file you actually did the design work in.
I am not able to open it.
Appears to be a 2021 file, we're on 2019 still.
Tried.
Edit your Lofted Flange 2-5 and set to New Solid. (Watch for interferences in your design.)
Add the Rips.
Follow the on-screen instructions for generating Flat Patterns with multi-body sheet metal parts.
Make sure that you have 5 bodies.
