Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
I am having issues with lines in Inventor 2016. Help?
4 REPLIES 4
j.delossantos3196
718 Views, 4 Replies
Hey everyone, I am trying to design a meyer copy
alto saxophone mouthpiece. When I try to make the shapes to define it more, the lines are 2 dimensional. How can I resolve this? I want the mouthpiiece to look like this:
but the blank and the lines in Autodesk Inventor looks like this:
and the measurements to make it are here:
4 REPLIES 4
blair
in reply to: j.delossantos3196
Welcome to the Forum.
Your sketch doesn't really match up to the pictures. It looks like a simpe Revolution should give you the main body with a simple cut for the flat where the Reed goes and another cut for the upp lip surface. Then create sweep profile for the center as I looks like the center opening isn't straight.
I would have to go down to my basement and dig out my old saxaphone to check if the center is straight or curved.
https://knowledge.autodesk.com/community/screencast/55807ab8-7305-4e4c-b715-3f3b612a3fcd
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
j.delossantos3196
in reply to: blair
Thanks!! How do you do the cut/revolution for the flat part and the upper lip part?
blair
This should help, I didn't use any dimensions just to speed through the process. It may take a bit for the video to upload.
http://autode.sk/23hVrPq
Delta Tau Chi ΔΤΧ
j.delossantos3196
in reply to: blair
thank you!!!!
