Hydraulic cylinder shown in retract and extend positions in same drawing view
bengee5454
bengee5454
hi all,
Having recently changed jobs I now find myself having to create a drawing of a hydraulic cylinder. I wish to show it fully retracted and fully extended in the same drawing view. Is this possible?
or do i have to lay 2 views over each other - this can't be the case surely......
Cheers,
Ben
swalton
I typically create 3 position representations in the cylinder model.
  • Fully Retracted
  • Fully Extended
  • Flexible (single constraint with limits set between the retracted and extended length)
In the cylinder drawing file, I create a Base View and set the Position Rep to Fully Retracted.  I then create an Overlay View and change the Position Rep to Fully Extended.  I can also change linetypes, shade and other visible styles.
I end up with a single view in the drawing of the cylinder in both positions.
I use the Flexible position rep in various assemblies that consume the cylinder.
Steve Walton
Inventor 2025
Vault Professional 2025
Paul.Normand
You can check out the procedure to create positional reps here:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-34C28C35-45CA-4476-9336-30146F7C9471
and overlay views here:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-00BDBDC4-CFA8-4BC2-936E-4028BB9FF0BF
Paul Normand
Principal Content Developer/SME
Design Lifecycle and Simulation (DLS)
Autodesk, Inc.
bengee54
That was exactly what I was after, I've been away from IV for a year, could not remember.
Added to that, I  had the unfortunate task of using SolidWorks for 4 months - which was far from ideal!
