HP Zbook Power G8 with Intel i7 11800H CPU
walter.tulin
Observer
Observer
walter.tulin
Observer
Observer
Hi, will Inventor professional 2022 work well on my laptop?
My specs
- Intel Core i7 -11800H base @ 2.3 GHz and turbo boost to 4.6Ghz
- 32 GB DDR4 3200Mhz ram
-512 GB PCIe NVMe
- Nvidia RTX A2000 , 4GB
I am not quite sure about the processor speed as Inventor requires a minimum of 2.5Ghz.
Please assist
johnsonshiue
Hi! I think it should be fine. I am running on a slightly slower CPU and the same amount of RAM with a similar graphics card. The performance is fine.
Many thanks!
Software Test Engineer
Gabriel_Watson
You can also set up under Tools (tab) > Application Options > Hardware to "Performance", and reduce your minimum frame rate under "Display" (App. Options tab), so your PC has a bit more leeway to run smoothly.
More tips here:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/Recomme...
