Can't export to 3D PDF
ferrisb
ferrisb
Inventor 2022
I can't export to 3D PDF, the little button is there in the annotate tab, but it doesn't do anything.
I don't see the option under File/Export or File/SaveAs either...
Any ideas?
Gabriel_Watson
Verify under Tools (tab) > Add-Ins, if when you select "Anark 3D PDF Publishing" both checkboxes should be selected, and look in Windows Explorer to see if you can find an existing C:\Program Files\Autodesk\Inventor 2022\Bin\AnarkCoreInventorAddIn.dll.
In case yours is corrupted, I am attaching mine zipped.
pcrawley
Another common problem is that the 3d PDF templates are missing.
Check your templates folder for:
  • Blank.pdf
  • Sample Assembly Template.pdf
  • Sample Part Template.pdf
  • Blank - DVR Carousel
If you can't find them, copy them from:
C:\Users\Public\Documents\Autodesk\Inventor 2022\Templates\en-US\
Peter
ferrisb
@Gabriel_Watson
Thanks, once again ya solved it!
I've gotta stop letting IT do my CAD installs...
