How to work with taper thread?
j.pavlicek
j.pavlicek
what is best workflow for taped threads? I want to apply ISO Taper (from bundled thread.xls) on weld nipple (ISO 4144 type 308). (R1 1/2" = DN40 pipe)
stainless_steel_150lb_316_35_of_57__7
This is a corresponding line from thread.xls
What shape a solid under the thread has to be?
  • Cylindrical?
    • What diameter?
  • Conical?
    • What diameter of the cone is crucial? Larger, smaller? (Apex angle is constant)
    • What dimension this crucial diameter has to be?
Inventor 2022, Windows 10 Pro
Sorry for bad English.
CGBenner
@j.pavlicek
Are you referring to the cosmetic thread feature, or are you planning to model the actual thread geometry?
For the cosmetic threads, all you need is the pipe OD and ID to be correct, and the thread should apply just fine.
Chris Benner
j.pavlicek
I'm talking about cosmetic thread. Thank you.
