How to use non-IBL lighting in Inventor Studio?
Amit262
Message 1 of 21
Amit262
The image in the IBL is reflected on the parts causing an image overlay that is not always desired. See the two screenshots below, the one with a greyish hue over the red is with IBL lighting in Inventor studio, The other one with well saturated red color is in assembly environment with 'Two Lights' lighting.
So it seems, in studio,  the grey wall of the IBL image is overlayed on the red colored part.
All the lighting in Inventor studio seems to be IBL based, how can I have non IBL lighting in Studio?
Thanks in advance
Greyish hue caused by Studio IBLGreyish hue caused by Studio IBLWell saturated colors if no IBL is usedWell saturated colors if no IBL is used
Replies (20)
Message 2 of 21
Daniel248
The grey wall of the IBL image is reflected by the red coloured part.
Try reducing the reflectivity of the red coloured part (in Appearance settings). Reduce glossiness also...
As far as I know, it is not possible to use non IBL lighting in Studio.
Message 3 of 21
Amit262
@Daniel248, Reducing the reflectivity or glossiness is not really a solution, may be a workaround at best. Besides, reducing the reflectivity/glosiness absolutely changes the look n feel of the part.
Isn't Inventor Studio for creating photo realistic renders? And there is no way to create lighting without an image overlay?? Really??
How are the professionals create renders?
Message 4 of 21
Mark.Lancaster
@Amit262
Inventor studio has been around for many years and hasn't really changed.  Inventor 2016 is when IBL lighting was introduced.
If you only need a rendering (no animation), I would actually recommend that you enable view realistic and ray tracing and not use Inventor studio for rendering an image.
Mark Lancaster
Message 5 of 21
TheCADWhisperer
This video doesn't address your question directly, but might indirectly answer the question.
If not, he has several other videos.
Message 6 of 21
Amit262
@Mark.Lancaster, I did actually use the assembly environment with raytracer to get some pretty good stills. And I must say they were better than I could manage with Studio.
Now, I need to create a video of a driven constraint, so I was hoping to get something out of Studio. But my initial experience with Studio hasn't been good so far.  Even the non raytraced view in the assembly environment looks more realistic than the default view Studio opens with.
Also, I tried the record function in the drive constraint dialog box. The video had horrible compression artifacts. Read several posts online suggesting to use Studio, so i gave studio a try.
Message 7 of 21
Amit262
@TheCADWhisperer, Thanks, I have already seen that video, very useful but doesn't address my issue exactly
Message 8 of 21
ToddHarris7556
Not to throw a 'cop-out' answer out there, but I think it's fair to say that Inventor Studio is a nicely-capable integrated rendering package, but it isn't 'what the professionals use'. Studio has it's limitations.
For more detail, control and quality, there tools like vRay, Keyshot, mental ray, 3ds Max, etc.
I'm not trashing IV Studio, but any of the tools in the dedicated rendering space will offer a LOT more capability for advanced needs.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
Message 9 of 21
Lewis.Young
Are you using one of the default Studio lighting styles?
Message 10 of 21
Cris-Ideas
I had a very long e-mail exchange with development after IBL was introduced to studio regarding very similar problem as you have.
So General answer is there is no way now to have not IBL lighting in Inventor Studio.
But
There is a way to define your own IBL lighting style where you can use your own image. I suppose you could use image that basically would be white. I am not sure what would he outcome be as I am not a master in rendering and stopped using studio at all.
I have found this link https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
have not tried though.
If you will please give some feedback.
Cris.
Cris,
https://simply.engineering
Message 11 of 21
ToddHarris7556
I admit I probably output 1 or 2 quick renderings a week out of studio to share with clients, mostly because I'm efficient enough at the timeline to get the task done there without having to fire up 3ds Max. It's useful enough that I keep doing it, but the artifacting does bother me.
I can't say great things about outputting to avi/wmv with limited control - I feel like it probably hamstrings the whole process.
Todd
Message 12 of 21
Amit262
@Lewis.Young
Yes, I am using Grid Light
Message 13 of 21
Amit262
@Cris-Ideas
Too bad 😞
I was thinking along those lines, about adding my own ibl. A white image will not work though because Studio will still overlay the white (the image in my original screenshot was close to white). Similarly I guess black will either darken or oversaturate the render. I am guessing a transparent png may do the trick but not sure if transparent pngs can be used in ibls.
I am trying it out now, will post back here with results.
Message 14 of 21
Amit262
Seriously I don't understand why is video output in such bad shape. The record button in drive constraint is such a big joke, then comes Inventor Studio, much better than the record button, but is still very unsatisfactory.
I don't get this, really how difficult is it to take a bunch of frames and stitch together a video?
"Autodesk Inventor Professional" cannot even output a decent enough video? really?
Message 15 of 21
ToddHarris7556
To be honest, I'm not sure if I really expect final output quality from a MCAD package or not.
It's pretty convenient to get something quick.
Re: improving the quality with cool lighting tricks... if you folks figure anything out, I'll look forward to learning how to get better quality. For ME, when I need better quality I go to 3ds Max (that's the rendering environment I'm least bad at)
Todd
Message 16 of 21
Cris-Ideas
It is not quick at all. It is as slow and as annoying as can only be possible.
Cris.
Cris,
Message 17 of 21
ToddHarris7556
Fair enough 🙂 Maybe 'quick' isn't the right word.
How about 'quicker than I can export out and set up in 3ds Max'
Todd
Message 18 of 21
Lewis.Young
One thing i found out early on is that the "Photo Booth" lighting style seems to look a bit better.
This is a 200 iteration render using Grid Light:
And here's a 200 iteration render using Photo Booth:
Although these are just quick renders, i have produced some really realistic pictures using Studio, so i wouldn't give up on it just yet aha.
Try changing the lighting to Photo Booth and have a play with the settings, let us know how it goes! 🙂
Lewis
Message 19 of 21
Cris-Ideas
For me personally it was much faster and a lot less frustrating to import to 3DS, link to a scene I have lighting set up before and render.
Only problem was that import was not working properly but even though this was far better solution than resultlesly fight with inventor studio.
Cris.
Cris,
Message 20 of 21
Cris-Ideas
Another idea come to my mind.
If you are not able to come to an agreement with lighting style maybe it would be some solution to place whole model inside a sphere (hollow) that would have self illuminating material assigned. (not sure thought if self illumination works in studio)
Than theoretical scene lighting style would be totally  separated from the model you are interested in rendering, so you would got no reflections from it.
Other thing that I had once noticed is that lighting environment in inventor has finite dimensions and it is technically possible to place model outside of it. Only not sure how it would then render.
Cris.
Cris.
Cris,
