I have created a couple virtual parts representing two types of "Assembly Instructions A & Assembly Instructions B in an assembly with several view reps. I need particular virtual "Instruction" parts to show up only in certain View Reps. I just want the correct Instruction to show up in the parts list that has a View Rep filter on it.
How does one turn virtual parts on (purple icon) or off (gray icon) in the browser?
There is no RMB menu item that seems to apply when selecting virtual parts in the browser of an assembly.
Hi Gary,
Virtual components do not have geometry. As a result, there isn't a visibility to control. The only way to alter its quantity is by changing its BOM Structure property (Reference). It is either counted (non Reference) or discounted (Reference). For this case, you will need multiple assemblies to get multiple BOMs (PartsLists).
Many thanks!
Hi Gary,
Many thanks!
I assume the instructions are specific to the assembly and not a general instructions? Is this a production assembly that will be ultilized multiple time's or all one off's?
Johnson,
I don't want anything to appear in the editing/model window representing the virtual instructions, they are just some paper pages that do not need to be shown.
I only need a row listing in the part list with the virtual part iproperties.
I can do it easily by making a custom part in part list but this assembly has multiple variations in it controlled by view reps. Each view rep enables me to create a totally different drawing/part list. I need to use a view rep filter on each drawing's part list. So I need to be able to turn the virtual part on or off in the browser only. If the browser icon is purple it's on & it's iproperties are visible in the part list even with a view rep filter on. But when the virtual part has a gray browser icon, it's off & virtual part iproperties do not show in part list.
It seems so simple & logical but there is no way I can find to turn the virtual part icon purple (on) or gray (off). That is all I need to do, it worked when I had only one virtual part. When I added a second virtual part, both virtual part browser icons turned gray & are not showing up in my part lists.
I just need a way to turn the virtual part on (purple icon) or off (gray icon) in the browser for each view rep in the IAM file.
Thanks, hope this makes sense.
Johnson,
Hi A. Acheson,
Thanks for the reply.
There are six assembly view reps & only two virtual part instructions.
If you read my response to Johnson you will see my goal is to have the iproperties of the one of the two virtual part "instructions" being visible in the part list depending on which view rep filters are turned on. Each view rep will be on a separate drawing IDW.
There seems to be an apparently half baked way virtual parts can be controlled in the browser by vanilla IV methods. A virtual part added into in an IAM shows a purple icon in the browser. The icon can also turn gray & be off in the browser & part list but I do not know how to control it on or turn it off.
That's all I'm after. If its not possible yet, then I'll put in a wish list request.
I saw a suggestion somewhere to just create an empty part.ipt instead of a virtual part & leave the origin point visible & it will allow for everything I need & could be reused. But I much prefer the cleanliness of no extra files & not having to constrain an exposed origin work point.
Hi A. Acheson,
Working with the drawing:
This iLogic code might suit your needs. It switches the visibility off for the virtual part via part number when a drawing view rep is changed. You might be able to set this up in a drawing template if the view reps and virtual part number are the same.
Correction on previous post I mentioned it might be possible to control the virtual part by changing it from a default to reference Bom Structure per view rep in the assembly. This is not possible.
To Use the below code run from a drawing file as an external or internal rule. Change the Text in red to the Part Number and View Rep Name required. This will only do two variations but if you need more try and follow the pattern and add in more variations.
It is only looking at the view on the current sheet where the parts list is so this may not work if your set up is different, if it doesn't work we can modify to the workflow you are using.
'https://forums.autodesk.com/t5/inventor-forum/ilogic-rule-scanning-partslist-rows/td-p/5184691 'Unable to capture current view rep of drawing, set view rep then check name 'https://forums.autodesk.com/t5/inventor-customization/api-get-the-quot-design-view-representation-quot-name-from-a/td-p/6335821 'Get File Doc Dim doc As Document doc = ThisApplication.ActiveDocument 'Check This is a drawing file If doc.DocumentType <> kDrawingDocumentObject Then MessageBox.Show("This is Not a drawing file, Exiting.", "iLogic") Return End If 'We have the Drawing Doc Dim oDrawDoc As DrawingDocument oDrawDoc = doc '[Change Virtual part and View Rep Here Dim VirtPart1 As String = "Component1" 'Place virtual part (partnumber)Here Dim VirtPart2 As String = "Component2" 'Place virtual part (partnumber)Here Dim ViewRepName1 As String = "1" 'Place view rep Name Here Dim ViewRepName2 As String = "2" 'Place view rep Name Here '] ' Set a reference to the drawing document. ' This assumes a drawing document is active. ' Set a reference to the active sheet Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc.ActiveSheet Dim oDrawingView As DrawingView '[Look through each view in the sheet in order to detect active view rep For Each oDrawingView In oActiveSheet.DrawingViews ''Set Drawing View Rep by providing a string value ' oDrawingView.SetDesignViewRepresentation("2", True) 'Relating to Assembly View rep'True =Associative,False = Not Associative Try ActViewRepDraw = ActiveSheet.View(oDrawingView.Name).View.ActiveDesignViewRepresentation 'MessageBox.Show(ActViewRepDraw, "iLogic-Active View Rep") Catch MessageBox.Show("Associativity of view is switched off!Cannot read Active View rep!", "iLogic") End Try Next '] '[Control the Partslist Item Visibilty ' Set a reference to the first parts list on the active sheet. ' This assumes that a parts list is on the active sheet. Dim oPartList As PartsList oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1) ' Iterate through the contents of the parts list. Dim i As Long For i = 1 To oPartList.PartsListRows.Count 'look at only the part number column oCell = oPartList.PartsListRows.Item(i).Item("PART NUMBER") If ActViewRepDraw = ViewRepName1 'find a specific value If oCell.Value = VirtPart2 Then 'hide the row oPartList.PartsListRows.Item(i).Visible = False Else oPartList.PartsListRows.Item(i).Visible = True End If ElseIf ActViewRepDraw = ViewRepName2 'find a specific value If oCell.Value = VirtPart1 Then 'hide the row oPartList.PartsListRows.Item(i).Visible = False Else oPartList.PartsListRows.Item(i).Visible = True End If Else MessageBox.Show("Drawing view rep not changing PartList", "iLogic") End If Next '] 'Homework It was raining '[[Get Model View Reps 'Dim oAssyDoc As AssemblyDocument 'oAssyDoc = ThisDrawing.ModelDocument 'Dim oAsmCompDef As AssemblyComponentDefinition 'oAsmCompDef = oAssyDoc.ComponentDefinition ''define view rep collection 'Dim oViewReps As DesignViewRepresentations 'oViewReps = oAsmCompDef.RepresentationsManager.DesignViewRepresentations ''define view rep 'Dim oViewRep As DesignViewRepresentation ''define an arraylist to hold the list of view rep names 'Dim NameList As New ArrayList() ''create a list of view reps 'For Each oViewRep In oViewReps ' NameList.Add(oViewRep.Name) 'Next ''ViewRepName = InputListBox("Prompt", NameList, d0, Title := "Title", ListName := "List") ''MultiValue.SetValueOptions(True, DefaultIndex := 0) ''Put them In a Parameter If needed To control By form ''MultiValue.List("ViewRep") = NameList ''Active view rep Of the model 'ActViewRepModel = oAsmCompDef.RepresentationsManager.ActiveDesignViewRepresentation 'MessageBox.Show(ActViewRep.Name, "iLogic") ']
Hi John,
Here, I would like to bring to your attention this behavior which slightly contradicts your statement about the visibility control of virtual parts. While it is true that the command is not directly accessible, the virtual parts still participate in workflows which toggle visibility or have visibility as a parameter. Namely: Isolate Components; Select All invisible components; Representations -> All visible
Please, take a look at the following set of screenshots showing a disruption in a workflow.
1: Virtual part is placed
2: Components participating in a constraint isolated
3: Virtual part gets greyed out as if it was invisible too
4: Selecting All invisible components includes the virtual component!!
5: As the virtual component does not have the visibility control, it disables the option for all parts!
6: The only way back is through this workaround:
7: Set up again.
Please, provide some feedback on this. Is that known limitation or something? In my opinion, this seems a bit half-baked and would require some revision.
Thank you.
Best Regards,
Martin Jezek
Hi John,
7: Set up again.
Thank you.
Best Regards,
Martin Jezek
Hi Martin,
Many thanks for sharing the findings! I am sorry I was not thorough enough. Indeed, the behaviors are inconsistent. The VC can be made invisible by Design View commands but there isn't a Visibility toggle in the context menu. I will need to work with the project team to understand the behavior better. It looks like a bug to me.
Thanks again!
Hi Martin,
Thanks again!
Hi Johnson,
Has there been any progress on resolving the Virtual part control issue?
I'm on Inventor version 2024 & I am still struggling with virtual parts that are grayed out in view reps & do not show up in part lists associated with the view reps. The iLogic fix is too complicated would not work for my application.
The only way to get VC icons to turn purple (& show up in parts lists) in other view reps is to unlock & turn visibility on for all parts in the v rep. But, of course, that defeats the purpose of the v rep.
Hi Johnson,
I found a work around that will make all the Virtual Component (VC) part icons purple in all the view reps (so VC shows up in part lists). But you cannot be using a Ballooned Items Only filter in the parts list.
