How to turn 3D model to Sheet metal
Julie-Tang
Julie-Tang
I want to make a 3D model into flat sheet metal part. It isn't allowing me to add bends to the edges. Can anyone provide a solution to this, thank you.
kacper.suchomski
Hi
  1. Sheet metal parts should be modeled using dedicated tools. Classic modeling tools should not be used.
  2. Create 2 sketches on the offset workplane and use the Loft Flange command.
  3. The sheets have rounded corners.
Kacper Suchomski
hollypapp65
One way to "fix" it.
johnsonshiue
Hi! As @kacper.suchomski already mentioned, this can be done in multiple ways. Here are 4 different examples in the attached file showing the techniques.
Many thanks!
Software Test Engineer
