How to teach myself inventor Pro 2015?
Message 1 of 12
I am looking to become pretty fluent in inventor and not sure where to get started, there are some books, etc I saw on amazin but are those to get me to "pro"ish level?
Its not for a job,  etc, just would be an awesome hobby to know how to use this program to its full
Replies (11)
Message 2 of 12
mdavis22569
There are tons of videos on YouTube. In the helps files and the knowledge wiki pages. Then of course there is the forums.
Reading the forums you can learn new things all the time...
Mike Davis
Message 3 of 12
How advanced is something like this? like id never know how to do all that stuff haha, but im a starter Render-13_zpsfr1p3r3b.jpg
Message 4 of 12
mdavis22569
That's not bad to model... However that's Showcase or something else that was used to render it. Depending on the part or assembly decides on hard it will be to render
Mike Davis
Message 5 of 12
Like for the midle gray piece, would I start with a circle, extrude it, but then how do i slice it up like that and put holes in  the sides? Like I only know how to put holes using 2d sketch after a part is extruded etc
Message 6 of 12
mdavis22569
Also do the tutorials that are provide with the software
Mike Davis
Message 7 of 12
where can i access the included tutorials?
Message 8 of 12
mdavis22569
Under help When you open inventor you'll seena projector icon Also with the commands of you hover over a command it will give you a hel box option with a how to usually associated to it. I'm not at my desk to include a screen shot
Mike Davis
Message 9 of 12
Ok cool thank you.
Now I was testing with selection of planes but I am having some difficulty.
How do I go ahead and select the side of the cylinder? All I can select is the top or bottom circle but not the side. I click plane and then click the side of the cylinder but then I am not sure what to do, I also tried the tangent to surface option plane.
Message 10 of 12
mdavis22569
Go to planes in the tab and here is a tang.lane option
Mike Davis
Message 11 of 12
mdavis22569
here is a image to show you where you can see Inventor help files and videos ..
this is how you do the plane on the cylinder, there are other ways depending on how it was modeled
Mike Davis
Message 12 of 12
Ah ok thanks yea like I was hoping there was an option to make the side the surface so I could put holes all the way around evenly spaced on the side of the cylinder
