I set up a simulation of an Alternator (or generator) for a wind energy system which I summarized in the model presented.
The large circular piece would be the Alternator, with a mass of 12,300 kg, which is welded to a 100mm Shaft. Both are connected to a Base by a Revolution joint.
In the DS, I applied a torque of 10 N.mm for 15 seconds, using the Input Graph and leaving the Previous and Later Sectors "Free".
The simulation time was 180 seconds.
I expected that with the applied torque, the Alternator would accelerate for 15 seconds and then, with the end of the torque, it would lose speed constantly, as there would be no force acting and the rotation is very low (23 rpm).
But what happens is that after these 15 seconds he keeps his speed constant, forever, even with zero force and acceleration, as the report presents.
Should I apply any friction to the joint? If so, how can I calculate this friction?
Or should I parameterize any other options?
What is missing?
